Grounding points *happy ending update*
Old Sep 3, 2004 | 02:46 PM
Hobgoblin's Avatar
Vehicle: 2015 Subaru WRX
Default Re: Stainless Steel Brake Lines GB #3
As the title states, where are they? Im thinking I have a bad ground, somewhere... hince why my car wont start. I just replaced the battery and nothing doing... I want to check the grounds, but I dont know where to look.
I did a search and found nothing on it...
Old Sep 3, 2004 | 03:48 PM
Default Re: Free Cam Sprocket Mod !
can you start the car if you jump it?
also, whe you say it wont start, what exactly do you mean?
Old Sep 3, 2004 | 05:11 PM
we need more info.. but to put it simply.. there is a ground to the battery at the fender (Smaller gage wire) and the large gage wire should go down to a central spot near the trans or to it directly... I would follow that one.
Old Sep 3, 2004 | 05:14 PM
Hobgoblin's Avatar
Default Re: Going to Capital Raceway Tonight (1/4 time will be up 9/
I was wanting to know where all the grounding points are in the engine. I know about the one behind the battery, just curious where others are.
Old Sep 3, 2004 | 05:18 PM
Dweet's Avatar
Default Re: Grounding points
three things to check...
1. when you put your key in and turn it to turn the battery on/radio whatever but not start it can you hear/feel the MPI relay click
2.do you hear the fuel pump hum when you do step 1
3. if step 2 and step 1 both work, remove cylinder 1 spark plug, and then put it back on cylinder 1's wire and put it near a bolt on the strut tower and crank the car.. if it jumps you have spark, if it doesnt jump then you have no spark and you should let me know and we will trouble shoot from there. if you do have spark then you are possibly not getting fuel or timing is off for some reason
Old Sep 3, 2004 | 06:11 PM
Hobgoblin's Avatar
Default Re: DIY - Resonator Removal
Oh yes it jumped! LOL These little kids running by sure thought it was funny!! heh
Old Sep 7, 2004 | 11:59 AM
Hobgoblin's Avatar
Default Re: DIY Mesh Grills
well, its been determined that it IS in the fuel lines.... yes you were right REDZ... (who has been sayin it from the beginning)
My car is on its way to a professional as I type....
Thanks for all the help though guys!
Old Sep 7, 2004 | 12:35 PM
Dweet's Avatar
Default Re: Custom Sub Box
if i car cranks but wont start always start by looking for spark, if spark is there look for fuel delivery, if that is there then its something really expensive smile.gif
Old Sep 7, 2004 | 01:44 PM
Hobgoblin's Avatar
Default Re: Gauge Group Buy GREAT DEAL from Splitfire!! NOW TAKING M
Im thinkin it is in the fuel delivery...
heh Im hopin that it isnt too expensive...
Old Sep 7, 2004 | 02:08 PM
Dweet's Avatar
Default Re: Grounding points *sad day update*
what part of the fuel line is it? also did you replace any part of the fuel line with regular fuel line and not "fuel injected fuel line", because if you did regular fuel line collapses under the pressure
