air filter + Sport exhaust
Old Aug 23, 2004 | 08:20 AM
memphisraines's Avatar
Default Re: Iceman Billet Aluminum Throttle Bodies!
HI!
Does anybody know the changing intervals of the air filter?
I want a sport exhaust with a really good sound. But which one should I buy?
David
Old Aug 23, 2004 | 08:23 AM
javageek's Avatar
Default air filter + Sport exhaust
Do you have a stock filter or are you using something like a K&N? You should get something like the AEM Cold Air Intake.
Old Aug 23, 2004 | 10:06 AM
canadianshark74's Avatar
Default Re: How I spent my Weekend Vacation (part 2)
change the air filter when it gets dirty, take the lid off your air box and have a look, if it looks black and filthy change it. If you have 25,000 miles on your car and have never changed it, then go buy one and change it.
OR
like Java said, go out and buy a Cold Air Intake, your car will appreciate it.
Old Aug 23, 2004 | 10:07 AM
01roller's Avatar
Default Re: air filter + Sport exhaust
you should clean it every 5k or 10k i believe
Old Aug 27, 2004 | 02:03 PM
x7xstring's Avatar
Default Re: Changing Spark Plugs
check it every oil change, or if you drive in dusty terrain, check it more often.
Old Aug 27, 2004 | 03:12 PM
UltraTibby's Avatar
Default Re: thoughts on airram and bbtb
01roller: you should clean it every 5k or 10k i believe
The stock filters cant be cleaned only replaced. If you are going to spend the money on a K&N filter you may as well go ahead like Java said and get the AEM CAI. The filter alown is about $20-$30 and the whole CAI is about $170. Not to mention if you are getting an exhaust that will help you output then getting this to help your input would make even more of a difference!
