PDA
View Full Version : Engine, Intake, Exhaust
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25
  1. Apex-i N1
  2. How to hone cylinder?
  3. Tips on reinstalling head?
  4. How often should plugs and wires be replaced?
  5. Cleaning Aem dryflow filter
  6. Mustang dyno vs Dynojet
  7. Where do you take your AFR reading from?
  8. Bling for my engine bay
  9. crank case filter
  10. Best stand alone on the market?
  11. Elantra RAM CAI
  12. Plastic intakes
  13. No Oil Pressure
  14. Pre-motor Build Build Question Thread
  15. Alternator Regulator
  16. Need a new muffler with a 3" opening
  17. Driving a car with a bad valve
  18. Starter Problems
  19. 2001 Cmp Sensor And Evap Purge Valve Codes Gotta Get Fixed
  20. sprayed my manifolds with header paint
  21. Power Steering Return Lines |:<
  22. OBX Radiator Hoses
  23. Loss of Power
  24. synthetic, or conventional?
  25. Custom Short Ram Intake
  26. valve cover venting solutions
  27. Paint safe degreaser?
  28. Aftermarket radiators
  29. Crank pulley info
  30. All black exhaust, Opinions?????
  31. Anyone replace their engines under 100K?
  32. Open loop and closed loop
  33. coolant smell
  34. Possible Injector Problem?
  35. Injector Questions And Help
  36. Adjusting Injector Pulse Width
  37. Exhaust Pop
  38. Took In Water
  39. Sticking Revs When Idle?
  40. Magnaflow, Flowmaster, or Glasspacks?
  41. Pcv Valve Location
  42. Misfiring, Super High Idle, Help!
  43. Are there any switch controlled exhaust valves?
  44. Clutch Squeaks When Depressed
  45. Picked Up A 98 Tibby Fx...
  46. Stripping Threads In Cylinder Head! Gimme Advice.
  47. High Flow Oil Pumps
  48. Show pics of your intake
  49. Dirty injectors
  50. Hyundai GDS Update
  51. Problems After Spark Plug Swap
  52. Cam gear cover
  53. exhaust gaskets
  54. Looking To Upgrade Pulleys
  55. High Idle....need Opinions
  56. Valve Lash and its effects
  57. Clutch Break-in
  58. How Do I Put More Fluid In My Trans?!
  59. ITB's
  60. Cylinder Head Replacement Probs Persist
  61. Race fuel in an NA engine
  62. Clutch Slave Mod
  63. Hla/valve Ticking
  64. Undercut valves? Anyone using them in here?
  65. 8yr warranty for Cat?
  66. motor pull
  67. Exhaust question
  68. removed my head this morning
  69. crank pulley
  70. aftermarket head
  71. ARP Acccent WOES
  72. Mitsu IM
  73. engine paint
  74. never seen this header before
  75. what is this?
  76. MSD Ignition
  77. Engine volume vs. physical size
  78. Resealing The Oil Sump
  79. Magnaflow & Flowmaster mufflers on sale - 30% off
  80. Nice article on how EGT gauges work
  81. Crank lightening, not knife edging
  82. Demise of the Dipstick
  83. Superchargers For Tibs ?
  84. Not Good Performance After 1.8 Cam And Ppim
  85. Custom fuel return system for 2003-2006 Accent 1.6L
  86. Question about valve train
  87. why do some catch cans have a breather and some don't?
  88. GK injectors
  89. Show me pics of your muffler
  90. Best way to polish stock intake manifold
  91. Short ram intake
  92. thinkin about puttin a oil pressure gauge in..
  93. Rebuilding An Engine, What To Change ?
  94. Car Won't Start... What Is It?
  95. DIY ceramic coating
  96. Short Shifter + Gear Knob
  97. My exhaust
  98. A few questions
  99. Hypereutectic pistons?
  100. So My Car Won't Start After Replacing The Clutch.
  101. Rod Knock?
  102. temperature questions
  103. Oversize Piston, Side Effect
  104. Injen Style Intake = Backfiring And Crappy Preformance?
  105. Time For A New Tranny...
  106. How do I apply Sea-Foam to my intake - I'm confused
  107. anyone else have this problem??
  108. moving to California- emissions question
  109. GlowShift Vs. Prosport Gauge
  110. Ram Air versus CAI
  111. Having some issues..
  112. Having Some Issues..
  113. Water Meth Injection on a NA engine.
  114. Exhaust Flange
  115. What causes an engine to eat oil?
  116. Few Parts, Need Some Help Figurin Out What They Are
  117. Fuel Injectors
  118. What's your favourite type of exhaust set-up?
  119. Is It A Chain Guide Noise?
  120. Quit Overheating!
  121. Alternator bolt and nut size??
  122. Spark Plug Question :p
  123. 5 Speed Swap
  124. AEM or K&N
  125. I Need A Dedicated Tuning Os.
  126. Any benefits to running an oil cooler on a car that just has bolt ons?
  127. 2.0 Some Extra Power ?
  128. ecu reflashing
  129. ECU System
  130. Rd1 And Rd2 Identical Engines?
  131. Throttle Body Spacer
  132. can someone explain what glasspacks are?
  133. 99 Stock Injectors?
  134. boring stock tb
  135. Tuning Haltech E6k.
  136. How difficult is it to swap a new catback myself?
  137. do accents have deceleration fuel cutoff?
  138. Seriously Considering...
  139. Advice For My 99 Elantra, What To Do Next?
  140. Resetting the ecu
  141. Aluminum meth tank. Anyone built one?
  142. Oil Pressure Sender Location
  143. Manual Swap !info Needed!
  144. Free flow cat question
  145. Fuel Rail Threading
  146. Car Won't Start
  147. Hood dampers
  148. How High Is You Clutch?
  149. Car Seems To Choke
  150. How Long Did Your Clutch Last?
  151. stock beta crank
  152. Bad Clutch
  153. Transmission Swap
  154. Cylinder Misfire
  155. Weapon R breather filters
  156. 2.5" versus 3"
  157. Post pics of clean wire tucks...
  158. Egine Swap
  159. Cruise Doesn't Quite Engage
  160. Clutch Lever Alignment
  161. Sparkplugf Newb Question
  162. Innovate LC-1 or AEM?
  163. Short Throw Questions
  164. Sticky Transmission
  165. is there a diff in the 2.0 motors?
  166. Increasing displacement
  167. Hydrolocked Engine
  168. 2004 2.0l Fit A 2001 Tib?
  169. System Upgrade Cam Gear Issue
  170. Newbs Need To Reply..... ;)
  171. Which engine oil is better?
  172. Exhaust has Rasp Sound to it
  173. Tuning Software
  174. timing advance
  175. REV iPhone app
  176. Fuel Injector Cleaner...How often?
  177. Exhaust Write-up
  178. O2 sensor cable
  179. Difference between 4-2-1 and 4-1 headers?
  180. Pothole Kills Transmission
  181. Gold Post At Bottom Of Radiator - What Is It?
  182. Do the 1.8 and 2.0 betas have the same horsepower?
  183. ARP Fasteners Part #'s for the Beta
  184. Fuel Filter Location
  185. Cylinder head flow testing for tiburons
  186. looking for new intake
  187. Accent P0301 Misfire
  188. Wavetrac Helical Differential
  189. Act Clutch And Fidanza Flywheel
  190. Need Help Finding A Muffler.
  191. Looking for a header
  192. Fuel pressure gauge?
  193. Benefits to double filter on intake?
  194. 97 Transmission Case
  195. Tranny Throwing Codes
  196. question about fuel injection
  197. Clutch Release Bearing
  198. Best products to clean an engine
  199. Dsm Crankwalk Problem Solved: Oil Squirters.
  200. Trans Blew :(
  201. Just A Quick Question
  202. 6 Speed For A 2.0?
  203. 1 Year Clutch
  204. intake temps
  205. Melted Plug Wire Ends
  206. Intake Manifolds
  207. Adjustable cam sprockets
  208. Opinions On This Flywheel
  209. New Engine, Or No New Engine.
  210. Let's All Play: Find That Leak
  211. what are filled motor mounts?
  212. Exaust Recommandations
  213. You ready for some Cali style smog laws down the road?
  214. Opinions On This Clutch!
  215. Coolant Leak, Please Help Me Asap,...
  216. Questions
  217. Boring Out Oil Pump?
  218. 1.8 Ecu's
  219. Running Rich
  220. Longer 5th Gear
  221. How long do you let your car warm up in the winter?
  222. Cold Starting Problems
  223. Crank Case Torque
  224. Head Gasket Replacement
  225. Won't Start? Help Please
  226. free flow cat
  227. Which Is Better?
  228. Rd2 Stalls And Loses Engine Response At Random
  229. Atf Fluid Sp-ii
  230. Getting Stuck In Gear
  231. I Guess It Is A Very Merry Christmas....not So Far
  232. valves ticking, changing oil filter question.
  233. Straight through or chambered?
  234. Having A Starter Issue.
  235. Don't Hone The Cylinder Bores For A Rering!
  236. Sensor Type Plug On Top Air Box?
  237. Manual Transmission Leak, Again!
  238. Dropping A New Motor/trans
  239. Power Steering Delete (w/ 1 Picture)
  240. Stock Rd1 Fuel Pump
  241. Engine Speed Related Whine
  242. Help!
  243. Cam Shaft Position Sensor Issue
  244. Single Throttle Bodies
  245. Going Turbo Checklist
  246. Transmission Swap List
  247. Shark Racing 268 Cams, Dual Valve Springs Now?
  248. Need Info On Tranny Ratios
  249. Shaving Cylinder Head 1mm = Timing Change . . . ?
  250. Eristic Head Gasket Set
