timing advance
Old Feb 17, 2010 | 08:52 AM
Red Tib's Avatar
Vehicle: 99 Red Tib
Default timing advance
my friend told me that if I advance the timing by 5 degrees and keep using high octane gas that it will give me more horsepower. is this true or all bs?
Old Feb 17, 2010 | 08:55 AM
the amount of hp youd get would be WORTHLESS
plus how are you gonna advance timing...not like we have a distributor lol
Old Feb 17, 2010 | 08:57 AM
^ What faith said. You're friend is severly misinformed. Thats basically a trick that alot of domestic and muscle guys will do to increase power from their bigger V8's, but for our engines...dont even bother trying.
Old Feb 17, 2010 | 08:58 AM
Red Tib's Avatar
Vehicle: 99 Red Tib
ok thanks. i thought so but just wanted to ask the pros here and make sure.
Old Feb 17, 2010 | 11:16 AM
racecar13's Avatar
Vehicle: 2002 hyundai accent
that was an easy 20hp on the old foxbody 5.0 mustangs. but to do it on our cars you would have to adjust the cam gear(s) 1 tooth on the belt. then your computer would go crazy trying to correct the advanced timing and make your car run worse. Of course, this is assuming you dont destroy the valves and pistons.
Old Feb 17, 2010 | 11:46 AM
or you can use a f/ic and use that to advance timing...but for the cost and the tuning of the fic your better off just running a 50 shot of nitrous
Old Feb 17, 2010 | 01:43 PM
warp21's Avatar
Vehicle: 2000 Hyundai Accent
Well I must be the exception to the rule here because I picked up quite a bit. While tuning my car on the dyno a majority of the power increase came from bumping up the timing.
Old Feb 17, 2010 | 02:09 PM
how much hp?
5?
at what cost?
a fuel computer, a dyno, and tuning
what other mods?
Old Feb 17, 2010 | 03:25 PM
radu_rd2's Avatar
Vehicle: 2006 Pontiac GTO
FIC can't advance timing, just retard.
Old Feb 17, 2010 | 05:31 PM
warp21's Avatar
It was over 10 hp gained before I even touched the fuel maps and I was already about +4 degrees over stock before even going there. The motor is an NA beta 1 with bolt ons so I’m sure some would say it wouldn’t be that much of an improvement if it was completely stock. However I street tuned a stock alpha with only a cold air intake and exhaust and was able to cut nearly ¾ of a second off of my quarter mile time, again seeing a majority of the improvement due to timing adjustments.
