Increasing displacement
Old Feb 23, 2010 | 06:58 AM
yellowtib's Avatar
Vehicle: 2000 Yellow Tib
Default Increasing displacement
Whats all involved to increase the beta's displacement from 2.0 to 2.2? And how much of a power increase could you expect by doing that?
Old Feb 23, 2010 | 07:00 AM
depends on why you wanna stroke it
Old Feb 23, 2010 | 07:16 AM
342Four's Avatar
Vehicle: '97 X3
you could bore it out by 40thou and that prob would drag displacement to 2.something
custom crank would be required if you want to stroke it out to 2.2L
Old Feb 23, 2010 | 07:34 AM
ElantraRage's Avatar
I often wondered this too. If the stock 2.0 is rated at 140 hp, then a 2.2 would have to be a bit more right?
Old Feb 23, 2010 | 07:42 AM
JonGTR's Avatar
I did the calculations once when I bored my block for the 83mm Wisecos, but it just barely got to 2.1L
Stroking a small motor is pointless. Just turbocharge it and get 3x's the power.
Old Feb 23, 2010 | 08:06 AM
its not rated at 140...its rated at like 132
and thats flywheel ratings
a 2.2 would probably give you 20ft/lbs IF THAT and youd lose top end in the process (you dont really gain hp in it, you gain torque stroking a motor)
stroker wiki
