Fuel Injector Cleaner...How often?
Old Feb 16, 2010 | 10:17 AM
plugboy's Avatar
Vehicle: 2000 Tiburon
Default Fuel Injector Cleaner...How often?
I use chevron gas and use injector cleaner every oil change.
Am I over doing it?
Old Feb 16, 2010 | 09:29 PM
omeletduefromage's Avatar
Vehicle: 02/hyundai/accent
i like to use some lucas oil fuel injector cleaner every 3 oil changes or about 3 times a year. i put it like a 1000 miles before im about to get an oil change though cause the fuel injector cleaner mixes with the oil and degrades the lubricating properties.
Old Feb 17, 2010 | 01:22 AM
I run a can of Seafoam into my fuel tank once a year or so.
Old Mar 29, 2011 | 04:00 AM
wheel_of_steel's Avatar
"fuel injector cleaner mixes with the oil "
i'd bloody well hope not - unless your accent is a 2 stroke
Old Mar 29, 2011 | 12:19 PM
^ in the same way gas mixes with the oil . . .past the rings.
Old Mar 29, 2011 | 10:07 PM
fair call, but i would say it is in such minimal amounts that it doesn't amount to anything. i mean, 400ml of cleaner in a 40 litre tank is a low enough concentration. if you then consider the amount of gas that would make it past the rings... unless your accent is a few million years old and throwing blue smoke out of the exhaust, i doubt this would be a problem.
