2.5" versus 3"
Old Mar 1, 2010 | 08:45 AM
tiburon423's Avatar
Vehicle: 2001 Tiburon
Default 2.5" versus 3"
The AEM and Injen intakes have 3" tubing but I see on ebay that alot of the cheapo intakes are only 2.5"
Is there a big difference in performance between the 2 sizes?
Old Mar 1, 2010 | 10:27 AM
accent718's Avatar
Vehicle: 2002 Hyundai Accent
That half an inch probably doesnt equate to much of a power difference.
Old Mar 1, 2010 | 12:09 PM
bdiggy's Avatar
How big is the port on your TB? If it's only 2.5, then upgrading the piping leading to it isn't going to do much for you.
Old Mar 1, 2010 | 12:11 PM
The 3" will have slightly better throttle response, but the 2.5" could possibly even make more power than the 3" because air velocity will be high. I think it'll have more to do with the design than the diameter though.
Old Mar 1, 2010 | 12:24 PM
JonGTR's Avatar
I believe the MAF is 2.75", so neither are ideal.
(I could be wrong since I haven't had one in 5 years.)
Old Mar 1, 2010 | 01:06 PM
warp21's Avatar
Vehicle: 2000 Hyundai Accent
I made mine out of mandrel bend 2.75" OD pipe only because it's the same size as the throttle body. Any larger or smaller and you would need to use adapters.
Old Mar 1, 2010 | 01:45 PM
bdiggy's Avatar
QUOTE (JonGTR @ Mar 1 2010, 02:24 PM)
There was a MAF in the 01 Tib? Either size would work with a MAF because the couplers are attached to either side of it,and yes, MAF is 2.75".
Old Mar 1, 2010 | 01:47 PM
JonGTR's Avatar
I got rid of my MAF 5 years ago when I installed a standalone and MAP.
Old Mar 1, 2010 | 07:37 PM
i8acobra's Avatar
Vehicle: '14 Ford F-150
Well, going back to the tests we did at HP back in '03... On the RD Tib, the AEM makes to most power out of all the (non-custom) intakes.
Old Mar 2, 2010 | 06:39 AM
Actually...if I remember right...the Random Special made the most power out of any intake on the market....even the AEM, but not by much. It definitely wasnt a nice looking intake though, but it worked well.
