Cylinder head flow testing for tiburons
Has anyone ever had their Beta bench tested for air flow? Im deciphering airflow numbers for our cars. I know that if executed properly the flow test results will be accurate, but they may not be indicative of the actual airflow in the engine and that many factors come into play during the dynamics of engine operation that cannot be duplicated on the bench, but can be mathematically predicted.
Those that have done it, did you check the intake port of the head with the intake manifold and companion components attached or did you do it another way?
