Looking for a header
Old Feb 1, 2010 | 10:40 PM
MINKISS's Avatar
Vehicle: 02/Hyundai/Elantra GLS
Default Looking for a header
im looking for a new header for my 02 elantra cause the one i got off ebay the guy lied about it and it dont fit right cause 2 stud bolts dont fit back on and there is no bung for the o2 sensor on the header only the downpipe. so im hoping you guys can help me find something good i would like a evofusion header but idk when there getting there next shipment in cause i want this befor eatco opening day but anyway does anyone know of any thing good and not pricey
Old Feb 2, 2010 | 07:37 AM
http://www.amazon.com/OBX-Header-Hyundai-T...a/dp/B001UHQIXA
http://www.ssautochrome.com/level.itml/icOid/1431
http://www.andysautosport.com/hyundai/1996...aders/kamikaze/
http://www.andysautosport.com/hyundai/1996...rs/spyder_auto/
http://www.kspec.com/list.php?ac_id=68&ai_id=1122
http://www.kspec.com/list.php?ac_id=68&ai_id=476
Old Feb 2, 2010 | 10:14 AM
MINKISS's Avatar
Ah you got my hopes but but sadly none of those will fit on my car they either don't have the bung that hoes to the manifold or it won't bolt to my exhaust
Old Feb 2, 2010 | 10:17 AM
you gotta peel the first o2 sensor back and connect it to the first hole on the header
then get a new cat and install the second sensor after the cat
id sell you my header for $50 bux
Old Feb 2, 2010 | 10:59 AM
MINKISS's Avatar
What kind of header is it and do you got a pic I can see of it
and peel back I don't follow my o2 sensor on the stock manifold when into the cat before I believe and the second o2 sensor was under the car on the down pipe
Old Feb 2, 2010 | 11:11 AM
you pull the wiring for the first sensor out of the loom it gives you enough wiring to relocate the first sensor further down stream
the headers with the hole in the stock location dont work because it only allows the o2 sensor to read the one runner off of the header
mine is just a obx one like ebay just used
no rust though
Old Feb 2, 2010 | 11:58 AM
^ What faith said. Any of those headers I posted WILL fit. You have the same engine as the RD Tibs, so any header you find for those cars, will fit your Elantra.
Old Feb 2, 2010 | 02:14 PM
MINKISS's Avatar
ok in still not understanding what to do with the o2 sensor im sorry if im being a pain but i just dont follow like were am i putting it down stream and such like do i have to have a bung put in the header or something but if you could explain it a little futhor it would help alot or a pic of what you are talking about would help even more for me to understand this more
Old Feb 2, 2010 | 04:30 PM
Where the front O2 sensor currently plugs into the exhaust manifold will be replaced by 4 individual primaries with the header. The O2 sensor (ideally) will be plugged into the header below where all the pipes meet. To facilitate this, you have to open up the wire loom and separate off some of the O2 sensor wiring or it won't reach all the way down to where the primaries all come together.
Old Feb 2, 2010 | 09:36 PM
ereeves116's Avatar
Vehicle: 2002 Accent
you should get a cat also, just make sure you have an o2 sensor on each side of it.
