- Weight Of A Betai And Best Way To Ship It?
- Beta 2 Parts?
- Transmission Problem?
- Stock Rod Length
- Battery Relocation
- Transmission Oil Fill
- Water Pump
- Flywheel Bolts
- Thought My Car Was Dead
- Sooo... I Have A Problem That Apparenly Isnt Uncommon...
- Slipping Transmission - No Not That Slipping
- Flex-a-lite Install
- Short Throw
- Switching Gears
- Starter
- Gear Oil
- Kickdown Servo Switch
- About Obdii
- Ignition?
- Rpm Drop At Wot
- Erratic Idle During Cold Weather
- Crank Patern
- Ground Wires
- Aftermarket Oil Caps
- Sticky Butterfly!
- Maf Low Voltage And O2
- Major Issues...
- Need Some Tranny/clutch Help
- Intake Manifold
- Fidanza Flywheel
- Auto To Manual Transmission Swap
- I Truely Need Your Guys Help.
- Engine Problem?..
- Transmission Removal
- Belt Broke In Middle Of Nowhere
- Sr Short Shifter Install
- Looking For 4.667 Fgr
- Rebuilding Engine Question.
- Misfiring...
- Problems With Clutch Start
- More Tib Problems
- Quick Coolant Question
- Low Com Pistons
- Power Pulley Set Owners
- Help With The Battery
- Coolant/water Pump
- Is This Cam Better Or Is The Same?
- Oil Viscosity
- Water Pump
- Another Clutch Option
- Fuel Filter Help!
- Transmission Problems Help
- More Tranny Help!
- Do You Really Have To Use An Engine Hoist
- Anybody Got Pics Of Pulling A Manual Tranny?
- Grinding Into 2nd
- Replace The Oil Pump?
- Mangaflow Muffler
- Harmonic Balancer On Crank Pulley
- Headers And The Mil
- Cryo Treat Axles
- Turbo Built Motor
- Questions.
- Who Can Do A Vhr Clutch Kit Install In The Pittsburg Area?
- Underdrive Pulley Or 1.8 Cam
- Rought Engine Around 3k
- Port & Polished Head ?
- Exhaust Manifold Tourqe Specs?
- Thud Noise From Steering
- Ac Belt Squealing
- Major Problem
- Replacing A T/o Bearing
- Performance Auto
- Injectors
- What Gives Better Numbers
- Belt Misaligned
- Hey Guys Im New Here But If U Need Anything
- Ran A Compression Test... Check Out The Results
- Royal Purple Atf
- G4gr Engine Question.
- New Parts Site For Almost All Motor Stuff
- Car Won't Stay On
- Misfire
- Headers
- Occasional Idle Problem
- Oil Caps
- Mobil 1 Synthetic
- Vhr Clutch After 12000
- Bizarre Engine Problem
- Transmission
- Engine Trouble
- Rear Coolant Drain Bolt
- Manual Transmission Fluid
- For Those Of You Who Have Vhr Clutches....
- Engine Stalls
- Backup Light Switch
- Bad Day At The Track For Loneshark
- So I Finally Got My Car Back..
- O2 Sensor Question
- Car Won't Start
- Ticking Sound When Runnign
- Engine Problems?
- Need Help To Take Out The Ecu
- Sr20det Into Rd1 Tibby
- Chance To Swap Trans...
- What Should I Do Next?
- Thinking About New Clutch
- Saw An Elantra At The Junkyard Today
- High Compression Pistons Q
- Magnetic Drain Plug
- Anyone Using A Wet System?
- Exhuast Problems/help
- Check Engine Light On...again.....
- Those With Newly Built Forged Engines...
- Shot Peen And Cryo Treating Rods.
- Lsd? Mtec Or Quaiffe?
- Airram Manifold
- Heat Wrapped My Header
- Tranny Help
- Few Questions About Some Products
- High Octane Fuel
- Regrind Cam Qustion
- Cel Question
- Grinding 2nd Gear
- Limp Stick
- Hollowed Cat...
- Boring...
- Supercharger W/ Turbo?
- Fuel Pressure Dropping!
- Don't Let Probs. W/ Tranny Go
- Got My Rside Header
- Just Installed My Cai
- Hydrolock?!?!
- Idle Adjustment Screw
- Clutch Chatter
- Just A Little Exhaust 101
- 1999 Elantra Wagon... Possibly A ? For Random
- Got New Tps, Didnt Solve Problem
- Need Performance Engine Mounts.
- Hwarang Intake/exhaust Cam
- Installed 58mm Throttle Body
- Obx Headers?
- 65mm Tb For N/a Engines
- Final Drive
- Anyone Are Using One Of This?
- Does This Sound Like A Faulty Tps.
- Car Stalls W/ Clutch In
- Compression Test Done Right.
- Question About Radiator.
- Clutch Pedal Noise
- My New Intake
- How Important Is It To Clean A Cai?
- Stupid Tps!
- Performance Question
- Compression Test
- Flex-a-lite Fans.. Requesting Feedback From Owners
- Im So Confused,just Got Back From Exhaust Place.
- What Do You Need To Make A Beta Rev To 9000 Rpm ?
- Clutch Advice Requested
- Twin Disk Clutchs
- Airram Mix Up?
- Just Changed Plugs And Wires
- Exhaust Stings My Ears
- 1.8l Ecu Swap
- Pop Question Regarding Tb.
- Got A Problem
- Changing Tranny Oil How?
- Engine Vibration
- How To Turn Off A Cel In One Step..
- Nology
- Cam Gear
- Project Gasmilage
- Need Help Asap
- Air Ram Question
- @$#& This Throttle Body...
- Ebay Intakes
- 1.8 1996 Elantra A/c Fan Work In 99 Rd1?
- Please Be Joking Alternator, Please Be Joking
- Vhr Clutch Kit!
- Hose Question
- Tranny Going Bad?..
- Big Problem
- Fan Turn On/off
- Need Tb Help
- Low Temp Thermostat
- '01 Tiburon 5 Speed Swap
- My New Exhaust!
- Airram Install ?'s Hopefully Answered
- Buying From Kspec - Need Help
- 300whp Stock Rods.
- Quick Question
- Wierd Cooling Fan Problem
- Ecu Pin Labels
- Air Filters
- Jerky Auto Tranny
- Weight: Fidanza Fw Vs. Vhr Fw?
- Tranny Swap.........
- 2.7l Delta V6
- Tranny And Clutch Question
- Finaly Did A Compression Test.
- Vacuum Gauge
- Doing A Tune Up.....
- Oem Heat Shield
- Engine
- Flex-a-lite Fans
- Auto To Manual + Engine Swap..
- Lost Power
- Quick Question About Manifolds.
- Cel...car Is Louder And More Powerful?
- Are These Any Good?
- Auto Tranny Help
- Found This On Ebay
- 2 Bolt Flanges
- This Doesn't Look Good.
- Ebay Radiator Hoses
- Automatic To Manual
- Wire/cable For O2 Sensor Extension?
- Engine Still Overheating - Need Ideas!
- Weird Tick
- Off Timing
- Look At This Bbtb
- Throw Out Bearing
- Type Of Cat
- Thermostat?
- Engine Choking?
- Ecu Serial Number Help!
- Intake Manifold
- Pistons
- Odd Noise At 3000rpm
- Flywheel Resurfacing.
- 1.8 Ecu With 1.8 Intake Cam
- Ram Air Intake For 2005 Tib?
- Ground Wires?
- Tranny Fluid Recommendations
- Engine Problems
- Short Shifters?
- Non Cruise To Cruise Control
- Bbtb Teaser Pic
- Copper Sheets!
- Rside Short Shifter
- Yea Baby!!! Exhaust At Last!
- Replacement For Shift Lever
- Iat Sensor
- Tranny Cooler
- Bbtb Gasket
- Canadians Needed!!!
- Wrx Swap
- Contemplating Rebuilding My Tranny
- Which Brand Of Spark Plugs Wires?
