Rpm Drop At Wot
this is not constant. sometimes it happening when I'm at WOT on 2nd gear, when RPM hit 4500 it stops accelerating for a couple of seconds then back to normal.
what is that? hot to cure it?
I'm having a problem when I'm on the highway. I have no trouble accelerating, however if I try to maintain a constant speed around 3K RPMs, it will hold throttle for a couple seconds and then drop to around 2K. I have a feeling it is TPS related. Hopefully it's a problem I can let go for a little bit..
hmm, today that happened again on 3rd gear.
I was accelerating (WOT) and when RPM hit 4000 engine slowed acceleration (like there was no fuel) and then continued accelerating till 6000 RPM.
I noticed it happens only when I have like
of gas or less.
I have 131,000 miles on engine (new rings 30,000 miles ago).
new fuel pump
new spark plugs
new OEM plug wires
changed fuel filter about 10,000 miles ago
just cleaned my air filter
of gas or less.I have 131,000 miles on engine (new rings 30,000 miles ago).
new fuel pump
new spark plugs
new OEM plug wires
