Rpm Drop At Wot
might wanna check on the plugs. samething happened to me this summer. i put in new plugs, but apparently the car didnt like them. i couldnt figure it out. i ended up throwin a CEL, brought it into Hyundai and thats when they told me the plugs were no good.
QUOTE (hamhead @ Jan 14 2006, 10:42 AM)
There is a flat spot in the Tib's dyno curve beteween 3500-4200ish RPM. I don't know if your noticing that, or a problem thats more severe.
Most twin cam engines have what is refered to as "twin cam surge" which is less noticible in an injected car than a carbed on. You can hide a lot with good fuel control. Anyway, most twin cam engines will have a flat spot about three quarters of the way through the powerband before picking up again at a higher rate. I think it probably has a lot to do with the flow dynamics of the head.
My Tib has it, My Fiat has it, just about every twin cam engine I have driven has it to an extent.
