Ticking Sound When Runnign
Old Sep 15, 2005 | 09:30 PM
00tibby's Avatar
i have a pretty loud ticking noise coming out of the injectors. i know this is normal but its louder than it should be i THINK. are they supposed to be loud? atm i dont have a injector spacer could that be whats messing it up?
Old Sep 16, 2005 | 06:52 AM
Loyen's Avatar
i second that question
Old Sep 16, 2005 | 08:32 AM
KayJai's Avatar
00Tibby, how many K's?
Last oil change was when?
What weight oil are you running?
Oh yeah, is your oil to the full mark?
Old Sep 16, 2005 | 02:25 PM
Dmitry's Avatar
Vehicle: Elantra HD / 2007
is there ticking sound after engine warm up and you rev it couple of times (like to 3K RPM)
Old Sep 16, 2005 | 02:38 PM
most of the time the ticking is either the HLA's or the idle air bypass
make sure your oil is alright and it shouldnt be a problem you might wanna get a engine flush if you are still within low mileage in order to clean up the hla's
Old Sep 16, 2005 | 02:40 PM
i got the same sh*t happening to me. is that coming from the injectors?? it's whenever i push the gas.
oil? what is the cause of this problem?
Old Sep 16, 2005 | 02:43 PM
Spiffywerks's Avatar
Take it in and have it looked at if its really bad. I had the ticking for the longest time, but it got *really* loud, so I took it in to have it checked out. Turns out the Oil Pump had failed due to a restraining gasket on the crankshaft breaking. The particles cloged the oil pump which resulted in the top of the engine not getting enough oil which caused damage to the head, and LOUD clicking.
What happened?
- Replaced Lifters
- Replaced CAMs
- Replaced Head
- Replaced Engine Block
--- Yep, I got a whole new engine.
Then, I started having 1-2 and 2-3 Gear shift problems. Result?
- Replaced Transmission
I got a whole new drivetrain at 65,000 miles.... all 100% covered by Hyundai, including car rentals.
Get it checked out.
Old Sep 16, 2005 | 08:06 PM
00tibby's Avatar
KayJay - 50k mikes
um a month. ill double check my levels. i forget the wieght.
also it seems to be coming from the injectors not the valvues.
Dm -
yes
Old Sep 17, 2005 | 01:02 AM
Dmitry's Avatar
I think with some OBD reders you can control injectors. Like with engine off you can click (on/off) each injector separately and hear does sound come from them.
Does frequency of that ticking sound increase with increased RPM?
Do you have stock injectors? What about fuel pump and regulator?
Old Sep 17, 2005 | 01:15 AM
Loyen's Avatar
in my case it increases
