Project Gasmilage
Old Aug 2, 2005 | 10:43 PM
JL_TIB's Avatar
ok so phase 1 is completed
it consisted of doing this
installed ngk plug wires from nopi.com- 39.99
installed ngk v grove plugs from discount/advance auto 1.68 x 4
gapped plugs at .44
before i was getting about 260-300 miles per tank now im sitting at 335 miles and not quite empty yet
also there was a miss and hesitation before, that is now gone.
also feels like ive gained a small amout of hp
this is on a stock 79k engine which i still need to change the oil out of , on stock exaust and a cone filter
next im planning to do what is called a fuel induction service
-clean tb/throttle plate
-clean intake plentum
-run seafoam though engine,
-drop in abottle or 2 of toyota fuel system cleaner (i got about 20 bottles laying around)
fill up tank
after that when i get some more money i plan to install high flow cats
Old Aug 2, 2005 | 10:49 PM
zoned019's Avatar
Vehicle: 97 Tib
i'd add ..
get a CAI
k&n air/oil filters
new OEM fuel filter
change oil
355 miles is pretty impressive.
Old Aug 2, 2005 | 10:59 PM
JL_TIB's Avatar
gonna use castrol gtw 10w40 high mileage with a wix oil filter (with is one of the best filters u can buy)
i dont want a cai because it rains so much here and roads are horribly designed (roads will retain massve puddles of water)
but i was looking at making a long short ram or relocating the battery and ill put the filter there
fuel filter goes that early in a hyundai?
toyota ones usally go past 100k
btw this is on regular gas
Old Aug 2, 2005 | 11:29 PM
zoned019's Avatar
Vehicle: 97 Tib
Fuel filters are SUPPOSED to be replaced like every 30k..
Old Aug 3, 2005 | 08:46 AM
Screwdriver's Avatar
355 Miles is good.
I get 400+ miles on every tank of cheap regular gas with an average of 30 mpgs in a mixture of freeeway and traffic. And I have 103K on my engine.
I just poured in some Auto-Rx to the oil. I firmly believe it will boost efficiency even further.
www.Auto-rx.com
Also, I've decide to use Shell VPower for the next 2-3000 miles and see how effective it is at cleaning the insides of the fuel system.
Next, I install my catback and headers with HF Cat. This will result in a very free flowing system. I believe that the best engine is an efficient engine.
When the time comes, I will have my head ported and polished and matched by a professional and get a new fuel filter.
My Current mods are limited to AEM's CAI + AIRRAM IM.
My advice, never drive above 60 if you want to save gas. Try to stay at a constant 55 with a light foot and minimize AC use as far as possible.
Good Luck.
Aviv
Old Aug 3, 2005 | 03:01 PM
brian01tib's Avatar
A full exhaust would help to, but also a SAFC so you can lean it out which should help out a lot
Old Aug 3, 2005 | 08:16 PM
I have consistantly gotten around 400 miles a tank.. and that is with some rather spirited driving, not accelerating like a grandmother (maybe not your grandmother.. mine LOVES big engined cars for a reason) but I also rarely use the air and I also rarely exceed 70mph for more than thirty seconds. (I will wind out the first three gears at WOT getting onto the highway though, just because I love listening to the CAI scream)
This on an engine with 112,000 miles on it.
Old Aug 3, 2005 | 08:27 PM
Alex01tib's Avatar
/\ 400 is real nice. was that when the light came on? i just got 363 without the low fuel light but i filled up because i was scared my light blew or something, then i filled up and did the math and i got 33mpg, woot! i still wonder how many miles i could have gotten on that wonder tank, Oh it was right after i did an oil change(used castrol), recharged my airfilter, and changed plugs.
Old Aug 3, 2005 | 11:04 PM
JL_TIB's Avatar
ok i got 361 miles out of the tank with fumes remaining
this was with mixed driving and the air was used about 90% of the time (been raining consistantly)
Old Aug 3, 2005 | 11:53 PM
Agarwal's Avatar
Knowing how you do "per tank" is kinda useless; calculate your MPG if you want real numbers to compare to.
