Gear Oil
Old Nov 28, 2005 | 10:36 PM
xtremeskier's Avatar
Well i changed my (manual) transmission oil tonight. I replaced it with 2 litres of Redline MT90, and then topped it up with Lucas Oil Stabilizer. I can't believe how much better the shifting feels compared to before. Great buy! fing02.gif
Tip: Add the Oil stabilizer first otherwise it's pretty hard to tell when it's full. I had to drive around a couple of times so the oil would mix with LOS and get warm so it would actually run out so i could tell if it was full.
2 Quarts of MT90, and about 1/3 bottle of LOS seemed to fill it nicely.
One question though, does it matter if i check the level when it is warm or cold????
Old Nov 28, 2005 | 10:47 PM
Alex01tib's Avatar
yah i changed mine recently too, love the shifting now, no more grinding when racing... i used royal purple because i heard it was better than redline, next time ill use redline to compare
Old Nov 29, 2005 | 08:24 AM
NightShark's Avatar
i got royal purple.. wooo hoo..
whats the specs on the the oil you guys used?
Old Nov 29, 2005 | 09:47 AM
JonGTR's Avatar
You only need 2.2 quarts I believe. Don't overfill it. Just keep pouring until it wants to come back out the hole (while your car is somewhat level).
I normally put in 1.5 Redline and the rest with L.O.S.
Old Nov 29, 2005 | 01:07 PM
fonseca's Avatar
Read this before using Lucas Oil Stabilizer.
Old Nov 29, 2005 | 02:12 PM
JonGTR's Avatar
Scratch what I said. I actually started using Pennzoil Syncromesh with a little Lucas Oil Stabalizer. It's in a yellow bottle.
But that link above is pretty interesting.
Old Nov 29, 2005 | 02:30 PM
fonseca's Avatar
It's very interesting. It seems to suggest that if you are using a good, properly formulated oil to start, adding a stabilizer is unnecessary and may not help, but instead can actually hurt the oil's performance, since it thins the original oil and the anti-foaming agents can no longer work as they should.
I'm using 20% Lucas. I plan to drain my gear oil after a long drive sometime and see how it looks. If there is air trapped, that would be a bad thing indeed. But I have my doubts as to how the tests in the above link translate to the conditions in our transmissions.
Old Nov 29, 2005 | 03:42 PM
NightShark's Avatar
is the lucas you use for engine oil the same for gear?
Old Nov 29, 2005 | 06:37 PM
Geez, makes me think twice about using that stuff now. And i just bougth a bottle for my oil change!!! Well at least it came with a model car. smile.gif
