Got New Tps, Didnt Solve Problem
Old Aug 23, 2005 | 07:40 PM
if two TPS's are both reading incorrectly, then it has to be a problem with the throttle body.
Old Aug 24, 2005 | 07:08 AM
Mad_john's Avatar
it should be reading .5 volts when closed
at 16% throdle is 2200 rpm at that is what my avc-r is telling me
Old Aug 24, 2005 | 07:52 AM
I know this is crazy, but maybe it's something with the Emanage or the wiring.
Old Aug 24, 2005 | 08:09 AM
Agarwal's Avatar
01: did you play with the adjustment screw? Did you reset the computer after installing back the stock TB?
Old Aug 24, 2005 | 12:43 PM
wattsup4800's Avatar
im pretty sure even though the idle adjuster is set differently, when the throttle is closed the TPS should still say 0%. Try cleaning the Throttle, do you have good throttle response.
Old Aug 25, 2005 | 03:25 AM
Dmitry's Avatar
Vehicle: Elantra HD / 2007
check idle speed actuator. It should adjust idle and add air when TB is closed.
