- Is the redline electronically controlled?
- Degreased and detailed my engine. Now its smoking
- Intake manifold
- Vented oil caps
- Custom Fuel Rail
- Experiences with Colt Cams and others?
- 2002 Elantra Exhaust
- Need a quick answer - Injen piping diameter
- Do flex pipes make a sound diffirence?
- ground wire
- How do you tighten the power steering belt?
- TPS Voltage
- What do you think is the most vital to monitor?
- Accent oil catch can
- Engine heat and LEDs
- how often do you check your oil?
- When you wire tuck and shave your engine bay
- Bad to drive with a misfire?
- Oil question
- Broken Timing Belt
- Crankshaft position sensor
- Good price for injector cleaning and flow testing?
- Time for an A/C recharge
- Best way to store a cam
- I love simple green
- Round Vs Oval
- Reusable oil filters
- Invidia N1 exhaust
- Custom plug wire covers
- help reading a vacuum gauge findings
- Fast question about battery relocation
- Gen1 Tib - need help in identifying sensor
- Painting silicone radiator hoses
- What do you know about O2 sensor?
- What is the ISA? and How to adjust TPS?
- skid plates
- Seafoam
- all motor tuning vs forced induction tuning
- question about forged pistons
- Aftermarket oil caps
- Is it a waste of money to buy a deep cycle battery?
- What's considered overkill as far as ignition is concerned?
- How much heat wrap do I need?
- fuel injectors and fuel economy
- Lasers To Replace Sparkplugs In Engines?
- to install msd or not
- What are the symptoms of low oil pressure
- OBO Error P0441 Evap Problem
- Heated Throttle Body: The Why and Wherefore
- Troubleshooting Cruise Control
- maf and intake sensors
- Inline Throttle Bodies
- Oscilloscopes anyone?
- is it possible to have a stock motor tuned?
- how do you change the exhaust tips on a GK?
- Cold Cylinder Leakage Test
- Sea foam
- Switching oil brands
- Throttle body options
- Questions about vacuum readings
- system cleaner
- What coolant Ratio?
- cleaning throttle body
- MAF Cleaner
- Exhaust Manifold Bolt Problem
- Cheap air filters for CAI
- timing problem
- Head gasket spacer question
- High heat engine paint for strut bars
- Do you think its worth it to do bolt ons with a lease?
- Question for those with headers
- Airrams with stock throttle body
- Synthetic oil
- Why is it so damn hard to find 3" exhaust options?
- sandwich plate adapter
- Headache
- E3 Spark Plugs? Anyone try them?
- Do hood spacers really work?
- washing engine
- Curious question
- What kind of engine hoist do you have?
- injector question , peak and hold vs saturated
- What are the negative effects to using an oil catch can?
- Air Ram Install
- Peanut Buttur Pulley Time!
- Beta1/Beta2 cranks
- cleaning injen intake
- turbo muffler
- Any reason to upgrade the fuel system?
- Do you think dealerships have better mechanics?
- Show me pics of your painted valve covers
- coating aluminum to resist heat?
- Best method to heat treat TB and IM
- Question about ethanol in the gas.
- coolant addictives?
- Does walbro fuel pump change PSI on stock fpr?
- Is truck bedliner flame resistant?
- need help with electrical system
- Cooling Question
- borla mufflers on a small engine
- Using synthetic oil in the winter
- universal 80mm throttle bodies??
- How are carbureted engines tuned?
- Who has had an Optima battery for a few years?
- Beta II head questions
- Air ram
- speed daddy headers review
- Leakdown Test Question
- ecu wires
- Power steering noise when its cold
- Technical discussion about HP, Torque, and Acceleration.
- How long do stock oil pan gaskets last?
- Goodyear Gatorback Belts . . . Are Poor
- underdrive pulley
- Time for Alternator No. 7
- cam shaft position sensor connector
- Why would anyone buy e85?
- clutch problems
- Need a new muffler with a 3" inlet
- Best Quiet Exhaust Setup
- Ark exhaust
- Extending 02 wires
- Box intake manifold project and discussion
- Crankshaft Position Sensor?
- About pauter rods - edm?
- Piston ring compressors
- 01 tib stock cat size
- Cleaning a winters worth of salt out of engine bay
- How to do a compression test?
- What do I do in the spring?
- Why do all cars have a Vacuum diagram?
- beta 1 to bata 2 valve cover swap
- need a stock beta manifold NOW! Will buy or Trade for Megan Racing Manifold NEW + $150
- Are there any pros or cons to adding more oil
- Trying to better understand how OEM ECU Learns, Air/Fuel Ratio and NA Mods
- Having coolant issues.Need some help
- Engine Rebuild Cost?
- Battery voltage?
- exhaust
- Valve lapping
- Question about the fuel system
- Intake or Exhaust mods and AFR, why AFR should be adjusted?
- 2006 I4 N/a tiburon
- can a piston go through the hood
- Best Oil choice when burning oil
- dreaming up an n/a tib
- Checking fuel pressure
- Excess blowby
- Header Questions
- Engine cleaner: Hose off type?
- Stuck Oil Rings vs Worn Oil Rings
- Injen Performance Parts
- What is the point of having a timing belt instead of chain??
- Fuel Injector O Rings
- When is it time to get a new engine?
- Broken Engine support bolts
- Gold battery posts or silver?
- underdrive pulley vs lightweight fly wheel
- colt cams wont idle
- Morning Cold Start
- E85 on a N/A engine
- What causes this?
- Rusty header
- question about wideband air/fuel ratio gauges
- Oil catch can question
- Widebands on NA car
- What intake are you running?
- What is the stock injector size for stock rd?
- Uh, Haha, Whoopsy!
- How to paint a chrome muffler flat black???
- Will changing sparkplugs after a retune screw things up?
- question about blueprinting
- What is it that makes some exhausts sound like weedwhackers?
- spark plug nonfouler?
- advantages to using aftermarket stud kit on n/a car
- What do you think about these headers?
- Quick question. Can you reuse the stock gasket when installing a header?
- Anyone who uses FRAM oil filters needs to watch this
- Should I buy my friends S-AFC for $25?
- Resetting ecu
- Anyone have pics of a blown beta head gasket?
- Ceramix coating exhaust piping
- Braided hose kits
- Radiator Flush
- Is line hone and line bore the same?
- Are Hyundai alternators swappable between cars?
- Beta? gone??
- How do people spin rod bearings?
- how much hp can the stock fuel pump handle?
- Weird fuel problem
- Improving the life of the starter
- On average, how much to have a 1.8 cam installed?
- Where can you buy raw carbon fiber mat?
- 3,000 mile oil change no longer needed?
- Pics of painted fluid reservoirs
- Lucas Fuel Injector Treatment
- What can you do to reduce the hp to whp ratio?
- I apologize if this is a stupid question but
- Submersible fuel lines?
- Dolphin tipped exhaust
- heavier oil in the winter
- O2 Sensor Code Wont go Away
- headers question
- Bizzare Idle
- XD EXHAUST THREAD!
- Installed My Header
- Which Optima battery is the best?
- exhaust wrapping procedure?
- crack manifold
- Crank Sizes?
- How many people are running an angled exhaust?
- What to do with a GDI?
- Are sandwich plates safe?
- Changed my spark plugs this weekend
- What FPR are you using?
- SRT4 injectors
- 2.5" exhaust piping without a header
- Stupid dipstick wont stay put
- What does YOUR exhaust look like?
- Do aftermarket catalytic converters affect A/F readings?
- Switching from conventional oil to syntheic oil at 161,000 miles
- K&N Filters & Filter Oil Do Not Kill Mass Air Flow Sensors (MAFs)
- ARC Cold Induction Box
- Crankshaft knife-edging
- What makes high mileage oil better than regular oil?
- Good engine builder in Wa???
- p0203 obd2 code
- Engine whine when A/C is on
- Fuel calculator
- Indexing spark plugs
- supertrapp mufflers, whats the reason behind the design?
- Does filter size matter any?
- very loud screeching noise when turning right
- NGK or Magnecore
- what kind of oil pan do you use to catch your old oil in?
- Is there such a thing as "over-camming"
- How often should the water pump be replaced?
- Piston question - lowering compression
- May have to do a quad exhaust after seeing this
- Anyone still use a G tech pro?
- Shaving the head or thinner head gasket
- oil, lube, and filter
- A Pipe (2002 Elantra)
- Really good article on engine cleaning
- New Piggyback ECU
- Hot coating intake manifolds
- Unorthodox Underdrive Pulleys
- Do you gap your spark plugs?
- A/C blowing warm air
- For the first time in my life
