universal 80mm throttle bodies??
Old Jan 31, 2011 | 08:00 PM
my98tiburon's Avatar
Vehicle: 98 hyundai tiburon
Default universal 80mm throttle bodies??
im just looking at little parts here and there for my tiburon has anyone tried these??? i see it mas to be welded on
Old Jan 31, 2011 | 09:38 PM
WytchDctr's Avatar
Vehicle: 14 EGT 2.0
Anything can be welded on, the real question is, is it a good idea. I am going to go with a no unless you have a custom intake manifold or something to back that up.
Old Feb 1, 2011 | 09:52 AM
Tibbi's Avatar
A BBTB is 58mm. What mods do you have that require an inch increase in the bore of the TB? On top of that, a like WytchDctr said do you have a manifold that will support the increased volume? You're talking about a volume of 3.5ci per inch of tubing up to almost 5ci.
Old Feb 1, 2011 | 10:32 AM
slow 2K2GT's Avatar
Vehicle: 2003 Hyundai Tiburon i4
That size TB will screw with the ECU since it will see regular voltage from the TPS but a lot more air will be rushing into the motor...that is of course like others said, you have the supporting mods to get that extra air into the manifold.
