What are the negative effects to using an oil catch can?
Old Mar 2, 2011 | 01:08 PM
vegac's Avatar
Vehicle: 2000 Tiburon
Default What are the negative effects to using an oil catch can?
Everyone always talks about how great oil catch cans are but are there any negative effects to using one too?
Old Mar 2, 2011 | 01:41 PM
Well, your throttle body won't get automagically lubricated, but short of that not really.
Old Mar 2, 2011 | 02:21 PM
steelcoffinx3's Avatar
Vehicle: 99 accent
You have to drain it.
Old Mar 2, 2011 | 02:36 PM
^ Winner.
Old Mar 2, 2011 | 11:10 PM
You have to drain it if your PCV valve gets stuck open or you have a turbo, mostly. Mine accumulates oil very.slowly.
Old Mar 3, 2011 | 02:33 PM
Regit's Avatar
Vehicle: 2000 tib
If you have a filter/breather on your can, you may get a whif of vapors now and then....other than that?
Old Mar 3, 2011 | 06:37 PM
holeshot69's Avatar
Vehicle: 1998 Tiburon
Ah it takes up space. A really good one doesn't, lol
Old Mar 3, 2011 | 08:01 PM
^ yup - doesn't have to take up space.
mine:
Old Mar 5, 2011 | 10:03 PM
krazytib's Avatar
I have had a few vacuum leaks on mine but I am also using a cheap air/water seperator that is for air compressors and actually says not for use with oil/fuel. I just replaced with internal o-ring with a thicker one and havn't had any more vacuum leaks. I also wrap the threads with teflon tape every time I dump the fluid but you shouldn't have to do that if you buy one designed for this purpose.
And draining it sucks especially if your car has alot of blow by. I removed my catch can from an old Honda I had cause it would fill up with oil in less than a week so I had to change it often and got tired of doing it. My Tiburon can go a month or more before needing to be changed.
These are the catch cans I built. I don't run that white foam piece inside anymore either.
