all motor tuning vs forced induction tuning
Vehicle: 2010 Sonata
Is there a difference in tuning an all motor car and a turboed car or is tuning tuning no matter what your set up is ? If so what are the differences.
read "Maximum Boost" and "4-Stroke Engine Tuning" Those 2 books will explain the difference to you.
It's way too complex of a question to ask and expect an answer in the format of a forum.
NA will run more timing and leaner afr than a forced induction motor. forced induction is less timing and richer afr's example: NA= 35 degrees advanced and 13.5:1 afr. Boosted= 22 degrees advanced and 11:1 afr. again just an example not actual for your motor all are different.
