Morning Cold Start
Old Oct 25, 2010 | 08:32 AM
AtomicX's Avatar
Default Morning Cold Start
Hey guys, lately I have been having issues with my car starting in the cold weather.
Every morning when I go out, the car takes forever to finally start. It sounds as if you are cranking on a dead battery.
It cranks, then after 3 seconds, sounds like the cranking is going to die, but then comes back and cranks, and finally starts.
This happens to me almost every morning and not just when I start it up.
If I start it up, drive about 10 miles to the store, when I come out of the store to start the car again, it does the same thing.
I have a good optima yellow top battery so what could fix the issue?
Old Oct 25, 2010 | 11:20 AM
Turboron_99's Avatar
Vehicle: 13 Gen Coupe Ult.
Just dont start your car, you wont have any issues...
Not sure man that is a weird question, could be your starter dieing, or i personally dont like optima, not sure if i just get ones that suck or what, but i have had three and now i am back to the electrolyte and lead batteries!
Do you know or have the ability to do a current draw on your starter?
Old Oct 25, 2010 | 12:01 PM
tib _500's Avatar
1. check that your alternator is putting out 14v to your battery at the terminals
2. have your battery load tested at an autozone or local garage/parts store
3. check you gounds and power wire to your starter.
4. suspect starter if all checks out and do as Turboron_99 stated or remove and take to a local parts store for testing
Old Oct 25, 2010 | 12:41 PM
Does it make a difference to press the gas pedal during cranking?
Old Oct 25, 2010 | 01:07 PM
AtomicX's Avatar
QUOTE (tib _500 @ Oct 25 2010, 02:01 PM)
Alternator is brand new, got replaced about 1.5 months ago when my other alternator died. I had the battery tested and it said it was a Good battery at Advance Auto Parts. Grounds are good, should be better then stock since I have a volt stabilizer and a bunch of extra grounds.
Old Oct 26, 2010 | 09:25 AM
tib _500's Avatar
id suspect the starter then if ur car is charging 14v, ur battery has been tested, and your grounds and power are good. o and u should still retest everything. new parts go bad often it seems like now.
ive had the same problem, but i have a battery drain i havnt found yet.
