How do people spin rod bearings?
Old Sep 20, 2010 | 12:37 PM
Cereal Killer's Avatar
Vehicle: 2005 V6 Tib
Default How do people spin rod bearings?
I hear about this happening alot on other cars. How or why do bearings get spun? I dont understand the concept of it.
Old Sep 20, 2010 | 01:22 PM
google
http://forums.about.com/n/pfx/forum.aspx?t...r&tid=15958
Old Sep 20, 2010 | 03:19 PM
UrS0NvS's Avatar
owner neglect is usually the main source which that link stocker provided pretty much named them all.
Old Sep 20, 2010 | 04:16 PM
i think ive ever ever heard of 1 hyundai spinin a bearing
and that was a beat on neglected pile
Old Sep 21, 2010 | 05:01 AM
MechaniX_034's Avatar
Vehicle: Lancer Evo IX
One outcome can have a crap load of factors that caused it. And when the rod bearing goes, you need to look at a few other things to suss out what exactly the problem was. Things such as which half of the bearing went first, or are both halves knackered? Did any other bearings go? What did the top of the piston look like? Things like that tell you what exactly caused the bearing to die.
Old Sep 21, 2010 | 07:56 AM
sprague1420's Avatar
Vehicle: 03' hyundai tiburon 2.0L
it could be also because or cheap/lack of oil.... or a wayyy over due oil change.... as stated above... neglect
also if your engine is making more heat than usual then the bearing siezes to your crank and tears your sh*t up
Old Sep 22, 2010 | 07:27 AM
I think the key issue here is that there are so many ways to do a rod bearing that it isn't actually possible to know how it's going to get done until you do it. Way too many factors involved. That problem gets compounded when you change the OEM specification(ie. modifying)
