clutch problems
Vehicle: 98 hyundai tiburon
clutch problems
i installed a new oem exedy clutch on my 98 tiburon and now after breaking it in while in first its like the clutch is slipping still?? i put a new slave in and it grips bettr but still on first gear it judders/vibrates as if it was slipping........ what could the problem be?
How much power are you running?
Did you have the flywheel resurfaced?
Did you have the pressure plate resurfaced or install a new PP?
I think it cost $20 to have a local machinist freshen up my stock flywheel, and it was in condition. That right there *could* be your problem.
i think it is the flywheel cuz the clutch grips great i figured its like putting new brakes on old rotors the new and old surfaces dnt go well
