Yet Another 5-speed Swap.
Old Feb 23, 2009 | 07:34 PM
tib _500's Avatar
so heres the low down...Im beginning to collect everything i will need to complete the auto to 5-speed swap. I know it has been covered like 1,000,000 times but i still want this to be reviewed and made a complete collection. Ive found a not so definite list of parts and the actual DIY threads. links: list , DIY.
currently i have established some of the parts needed and already ordered them. they are as follows: shifter, linkage, clutch pedal, clutch slave cylinder.
I also know i will need a transmission, clutch, and flywheel. but that is another discussion i would like to have with the RD community. options being Beta I 00-01 tib tranny, Beta II elantra tranny, or Beta II tib tranny info. i want input on the difficulties and diferences in the swap. I already know the mount needs ground to fit but i need to know starter and flywheel info as well. I seen the starter location is slightly different from beta I to II info.
any help or suggestions welcome.
new info Beta 2 tranny optimo's , extremly helpfull! , Landshark's
spell check complete
also will a mod close the other thread i somehow made two.
Old Feb 23, 2009 | 07:58 PM
UrS0NvS's Avatar
lmao, n0ob, wrong button
so heres the low down...Im begining to collect everything i will need to complete the auto to 5-speed swap. I know it has been covered like 1,000,000 times but i still want this to be reviewed and made a complete collection. ive found a not so definite list of parts and the actual DIY threads. links: list , DIY.
currently i have esablished some of the parts needed and already ordered them. they are as follows: shifter, linkage, clutch pedal, clutch slave cylender.
I also know i will need a transmission, clutch, and flywheel. but that is another discussion i would like to have with the RD comunity. options being Beta I 00-01 tib tranny, Beta II elantra tranny, or Beta II tib tranny info. i want input on the difficulties and differences in the swap. i already know the mount needs grinded to fit but i need to know starter and flywheel info as well since i seen the starter location is slightly diferent from beta I to II info.
Old Feb 25, 2009 | 01:42 PM
tib _500's Avatar
does any one know if i need to get a manual starter for the beta I or II trannies? also can i use a beta I clutch and flywheel on beta II?
Old Feb 25, 2009 | 02:28 PM
The starters were different on my B1
Old Feb 27, 2009 | 05:22 PM
tib _500's Avatar
can anyone help me out here? as you can see ive searched the f*** out of this site. i need to know whats different on the starters and clutches on Beta I and Beta II tranies. i need to know if tranny mounts and starters on autos and standards are the same. can I use a Beat I clutch and flywheel setup on a beta II tranny?
im going to use 00+ Tiburon parts. maybe Beta 2 Elantra tranny if i get a great deal(not likely).
I really need some help on this guys. ill take pics of my clutch in my auto car as soon as i find my camera. the swap officially started today @5pm. and so far ive got the clutch and slave cylinder installed .
Old Feb 27, 2009 | 11:32 PM
Have fun.
The mounts, you only need to change the driver's side mount if you want the bracket for the clutch slave cylinder hose to be correct. The A/T driver's side mount is reinforced for the frikken heavy automatic. The manual mount has a clip to hold the clutch hose. I'd hate to have that hose worn through, so I changed the mount.
I want to say the clutches are the same, and pressure plates. Flywheels should be too, after 07/99 engine manufacture date
Starters have a different amount of engagement in the ring gear, IIRC the auto starter won't reach far enough into the bellhousing to turn the flywheel.
Now is a good time to fill the front/rear roll stops with silicone rubber to reduce engine rocking.
You've done your homework. If you still have a question, ask away.
Old Feb 28, 2009 | 12:33 AM
purpletib's Avatar
Vehicle: 2000/Hyundai/Tiburon
It should be noted however that your parts list link is a dead thread asking the same thing, lol
Old Feb 28, 2009 | 11:46 AM
tib _500's Avatar
alright, all ive got to get is a tranny and starter. this maybe swaped before summer. another $300 and it will be a go! for now ill use the auto tranny mount. ill be changing more stuff out after its in and working. looks like ill be getting a 03 Elantra tranny because its like $200 cheaper.
Old Feb 28, 2009 | 12:39 PM
Beta 2 trans needs beta 2 starter. The clutch and flywheel should be the same. You will also need the starter plate I think for the Beta 2 trans.
Old Feb 28, 2009 | 08:55 PM
That would be the thin piece of metal between the bellhousing and the engine, the holes are cut differently IIRC. Come to think of it, I don't remember if the driver's side mount would bolt up. It's close but I stupidly didn't make a direct comparison, sorry.
