I passed emissions today, with a gutted cat
Old Sep 14, 2009 | 01:48 PM
jsharptooth91's Avatar
Vehicle: 2002 Accent 2.0L
Default I passed emissions today, with a gutted cat
So last week my internals of my cat fell apart. I removed all the honey comb stuff and popped it back in. Since then no cel has come on. I needed tabs go went down and took the test and passed with flying colors.
I would of failed if they did the sniffer test, but its just hooking up to the ODB2.
That makes me think, is my car running okay?
Old Sep 14, 2009 | 02:14 PM
Accents seem to be hit or miss with CEL's on catless cars. Not having a cat won't make the car run worse though from my understanding, just turn on the CEL. Corrections are made based on the precat O2 sensor, the after cat sensor is only to verify that the cat is functioning properly when checked against the precat O2 sensor's readings.
Old Sep 14, 2009 | 04:45 PM
you can pass because the readiness monitor hasnt set yet
most places will let you pass with 1 monitor not set
once out of curiosity i put my car on a sniffer test...and passed a sniffer test with no cat
Old Sep 14, 2009 | 06:08 PM
ereeves116's Avatar
in my part of town they only do CEL checks on emissions. I have a CEL so i can't pass but if I reset the ecu and temporarily clear the CEL, will I pass?
i totally tried to jack this thread i'm sorry
Old Sep 14, 2009 | 06:49 PM
Its all good. Now im debating if i should buy a cat and be legal?
Old Sep 14, 2009 | 07:06 PM
yes and no
you can clear the codes and drive it around until all monitors are set
but the second it sets that monitor for the cat your screwed some systems will do it right away others take a day or 2
obd2 is smart it KNOWS when you disconnected the battery
Old Sep 14, 2009 | 09:31 PM
with the cat gutted i get bee sounding. i dont like that, soo i think thats why im going to get a cat...meow
Fintile's Avatar
lucky you. See in Cli you get both sniffe and OBDII sensor test...you also get the wonderful "visual" test. Sucks cause unless you look stock, have a great tune on the car you cant get away. Even then ppl resort to paying $300 to "pass" smog.
Old Sep 17, 2009 | 08:45 AM
UnnaturallyAspirated's Avatar
Vehicle: 1998 Hyundai Accent
LOL try moving to Ontario, Canada!
Sniffer test, curb idle test, and 2nd gear 2500 rpm load test, plus full visual inspection.
good ol' Ontario "DriveClean" program.
Old Sep 17, 2009 | 09:30 AM
in jersey you actually have to run it on a dyno
sniffer, brake test, EVERYTHING
