Rythmic Tapping From Tob
Old Apr 5, 2009 | 08:17 PM
My throwout bearing was making rhythmic tapping noises when I let the clutch go quickly in neutral. If i let it go slowly, it would not make any noise. Today, I noticed that I had some up and down play in the release fork shaft. It was due to a missing washer under the 14mm m10-1.25 nut on top of the release fork shaft. I put the washer under the nut and the rhythmic tapping went away.
I'm just wondering why... How would play in the release forks make a noise when the clutch was released quickly and not slowly?
Old Apr 5, 2009 | 09:29 PM
If you let it go slowly, it has time to slide to where it needs to be. If you let it go fast, it has to change position suddenly and it jumps and bounces.
Old Apr 5, 2009 | 10:16 PM
Well, that's as good of an answer as any.. The actual movement involved still dosn't make any since to me, as far as what was causing the noise.. I just am glad it's done. Figured I'd post here about it in case someone has the problem in the future.
