Faulty Pressure Plate?
Old Jul 3, 2007 | 08:37 PM
rusomen's Avatar
Hey guys i gotta question
Can Faulty PP to cause to first gear to jump out and second gear to grind at WOT?
also is it a big problem that my flywheel was kinda curvy??
by curvy i mean 6 puck is a little bit smaller in diameter then OEM i think so that place where 6 puck is sitting is grinded off
any inputs will be appreciated
thanks
P.S ALSO here's the video
WIERD!!!
that only appears in 2ng gear when i'm releasing gas it goes back and forth couple times and then when i'm pressing gas it goes back in place
why is that happening ???
Old Jul 3, 2007 | 08:54 PM
Loneshark's Avatar
Vehicle: 2000 Tiburon
NO
your syncros for second are bad.
that will make it pop out of gear.
grinding at wide open throttle ?? you got more problems that just the clutch, sounds lke your tranny is f***ed
your flywheel is curvy ? what the hell does that mean ?? its supposed to be round, owned. LOL
in closing, your tranny either has bad gear oil, no gear oil, or bad syncros.
soon you will not be able to even put it into second gear with these symptoms
Old Jul 6, 2007 | 11:43 AM
Korean_Redneck's Avatar
Vehicle: 1999/Hyundai/Tiburon
Try using Synthetic Amsoil MTG or Redline MT-90. All of my grinding whoes went away when using those oils.
Old Jul 6, 2007 | 06:42 PM
rusomen's Avatar
lol too late already yesterday my tranny blew now i know what cause all the noises and all other bad stuff that happend
it was bearing inside tranny that pass. axel goes in it fell apart and went thru all gears :@ lol
it still drivable but with alot of noise and only in first gear
so yea i'm looking for 5spd tranny right now..
