Moisture In Plug
Everything I know about engines, I've learned from experience. SO, I've learned that if I clean my engine with spray-down-cleaner, and my engine acts weird a day or two afterwards, it means that I wasn't careful enough to keep water away from my spark plug cover. Well, no matter how careful I am, I always foul the plug on the far right. I disconnect the battery, pull the wire, and pull the plug, always to have the plug literally dripping with water. I dry it all off, and reassemble. Back to life as normal.
Here's my question... When I mentioned this today at work, someone said I was probably losing power due to the wire plug not sealing, even when there isn't moisture in there.
What do you engine gurus have to say about this?
