View Poll Results: Power steering noise, only for those with UR crank pulleys?
yes, with atf
16.67%
yes, with power steering fluid
66.67%
no, with atf
0
0%
no, with power steering fluid
16.67%
Voters: 6. You may not vote on this poll
Squeeky Power Steering With Aftermarket Pulleys?
Old Feb 3, 2007 | 02:34 PM
so i have completely bled my power steering system, and have tightened that belt beyond belief. my power steering still squeals loud enough to set off car alarms in my parking garage when its lower than 40 degrees out.
i think it has something to do with the underdrive crank pulley i installed. i am also using power steering fluid instead of the recommended atf.
Old Feb 3, 2007 | 03:55 PM
Trancematic's Avatar
Yes, mine does aswell only under certain cirumstances..
A) Turn the wheel far left/right
B) Has to be cold outside
Occurs maybe once every 3 weeks, but then goes away after a couple seconds.
Old Feb 3, 2007 | 04:38 PM
pbdude23's Avatar
Mine does that also under certain conditions. I changed the pump once and it stopped. However, it has just started up again. I'm not to sure what it could possibly be.
Old Feb 3, 2007 | 05:20 PM
hprockets's Avatar
Vehicle: 2009 Hyundai Sonata
mine did that but stopped after i tightened the belts
maybe change the belts? i have goodyear gatorgrip
Old Feb 3, 2007 | 06:16 PM
i have those exact belts.
it got much better when i bled it today, but still squeals. im going to bleed it tomorrow until my battery runs out of juice.
Old Feb 3, 2007 | 06:45 PM
Double_A's Avatar
No man, its not the system needing to be bled. I have read multiple threads about this here on this forum. I had the same problem. It was VERY loud, but only when it got on the cool side. It would squeak as long as the car was on, it never went away.
So i changed the pump and it all but went away. It is still there, but it is very faint.
I too have a UD pulley, but it started squeaking long after I installed that.
Old Feb 3, 2007 | 06:53 PM
mine only squeals on startup though.
every time i bleed it, it gets better. i took out the whole ps reservoir so a lot of air was introduced. im thinking there is still some in there. it happened right after i did that.
Old Feb 4, 2007 | 12:18 AM
QUOTE (Trancematic @ Feb 3 2007, 03:55 PM)
Exact same here.
Old Feb 4, 2007 | 01:04 PM
01steve's Avatar
Vehicle: 2000 hyundai tiburon
my old rd2 had that problem-... and it doesnt' even get too cold down here in the sunshine state.i'm gonna experiment w/ something, when i get my new pulleys. i'm gonna get my new pulleys sandblasted (on the side where the belt makes contact). i'm hopeing that the gritty-ness will prvide extra grip on the belt and thus stop the belt squeal. i'll let you know how it works out (whenever i can get my hands on a set of pulleys).
Old Feb 5, 2007 | 11:50 PM
bumpers...
i know there are more with underdrive crank pulleys...
knowing that people with underdrive crank pulleys and even stock ps pulleys will elminate the underdriving from the equation.
