I need piston dimensions
I found forged pistons (diametr 82mm) but for another car.
For only $140 (NEW!)
So I need to know dimensions of stock pistons or turbo pistons on Tib 2.0
I need:
1. Compression height (CH)
2. Pin hole diameters (PB)
3. Overall length (OL)
PS. if it's possible other dimensions.
DH + dome or DI dish
VR = Valve recess depth
BD = Cavity
AA = Distance between bosses
M0 = Combustion chamber diameter
MV = Combustion chamber dia.
F = Top land width
S = Crown thickness
St = Ring land width
SL = Skirt length
NH = Ring Groove width
DL = Crown underside to pin hole
I need:
BD = Cavity
F = Top land width
S = Crown thickness
SL = Skirt length
Yes only $140 for 4 forged pistons, same diameter as Tib has.
It's for VAZ (or LADA) russian car.
Tuning for russian car is very cheap. You can buy cam for $70. Remap ECU for $50-60.
There is a place, where you can make forged pistons for any car for $100 for 1 piston. You just need dimensions or original piston.
May be somebody knows stock piston's dimensions?
