Rebuild Kit
Old Dec 8, 2004 | 02:17 AM
Wolfie's Avatar
Vehicle: 2000 Tiburon
Default Re: Pictures of the tiburon
Hey guys,
Does anyone know where i can purchase a performance engine rebuild kit for the Beta 1 online?
Old Dec 8, 2004 | 05:46 AM
Agarwal's Avatar
Default Re: Tips for cleaning?
AFAIK, there's no such thing as a "performance" rebuild kit for the Beta.
Old Dec 8, 2004 | 07:31 AM
1997tibby's Avatar
Vehicle: 02 Accent
Default Re: December 7th 1941
Believe it or not, autozone sells a rebuild kit for our engines, its not a performance rebuild though, not sure on price.
Old Dec 8, 2004 | 10:30 AM
Dweet's Avatar
Default Re: North East Meet 18/19 ??
QUOTE (1997tibby)
thats news to me..
anyways back to the original question. why are you rebuilding your engine? You want to run boost? You want to run higher compression? Or do you want to do a basic overhaul?
Old Dec 8, 2004 | 04:29 PM
Jaws021's Avatar
Default Re: NW/West Coast Members
all a performance rebuild kit is...
bigger pistons or slightly higher compression...
Get yourself new bearings.. new rings.. new shims... BAM!
there goes your rebuild kit...
Also get some headbolts, head gasket, water pump gasket, oil pump gasket, thermo housing gasket,.... thats about it.
Should run you around 125-150
Rebuilding the block could cost you around 300-500
If you have someone also install the block for you... look at spending another 500-1000 for labor
I Recommend you find a nice used beta engine at a local junkyard. The will cost you about 300-500, and youll have a nice almost new engine for less the price.
Old Dec 8, 2004 | 04:31 PM
silvertibbs's Avatar
Vehicle: 2004 Acura TL
Default Re: Slim/thin fans?
Don't forget down time due to not having an engine.
Old Dec 9, 2004 | 01:16 AM
Wolfie's Avatar
Default Re: Redzmans Birthday - Dec 9th
Hey thanks guys. It's for an overhault, my engine has many many many miles on it laugh.gif . I also may be going boost or n2o (with stock compression) in the future so that's why i was asking for a performance kit.
I did however come across this :
HP Engine Kit
For 96-98 Elantra/Tiburon
http://www.importshark.com/store/engine.htm
Do you think it is worth the money. Or should i just get the parts individually, as Jaws suggested ?
p.s. the block should not need a rebuild.
Old Dec 12, 2004 | 03:35 PM
Wolfie's Avatar
Default Re: Previously unreleased Tibbychick lingerie shot.
Old May 31, 2005 | 04:59 PM
buffbentley's Avatar
What about this engine kit? Is it a good deal? I will be running nitrous.
http://www.importperformanceparts.net/impo...ek-hyundai.html
Old May 31, 2005 | 05:13 PM
gmantibby's Avatar
Both good brands of pistons. Stay 8 5 1 for boost. I've seen ross in alot of turbo eclipses I don't know how the price is though, I know pistons get very expensive for our cars. Don't forget your head. Prolly need all new valves and guides. Might as well since you got it apart.
