High Oil pressure
Old Nov 16, 2004 | 12:31 PM
alz99's Avatar
Vehicle: FX Coupe
Default Re: Check out these gauges
Can the guys/girls running oil pressure guages tell me how much psi you are getting on cold start and once the oil is up to temp..?
I have started to notice that my oil guage (sender at the head) is reading a bit high,
80psi over 2,500rpm and 60psi ona cold start, it used to be at 60psi cold start then drop to around 30psi, something funky is going on i suspect maby a clogged filter or release valve spring,
i just wanted to check first, the oil sender unit is tapped into the top side of the main oil gallery.
Help../ thanks
Old Nov 16, 2004 | 12:37 PM
silvertibbs's Avatar
Vehicle: 2004 Acura TL
Default Re: Tiburon part out
I dunno yet as soon as I install mine from our group buy I'll let you know. Hopefully someone responds first cause it may be a while until I even get them.
Old Nov 17, 2004 | 09:08 AM
azwildfire's Avatar
mine is 45 psi at idle and jumps over 80 psi under load above 3.5k rpms
Old Nov 17, 2004 | 11:55 AM
alz99's Avatar
Vehicle: FX Coupe
Default Re: Speaker and System for sale
azwildfire - can i ask you where is your oil pressure sender is located? ie tapped into the block/head,
what grade oil and when was your last oil change...?
thanks man. you have a 1st or 2nd gen?
Old Nov 17, 2004 | 12:03 PM
TibRacer01's Avatar
Default Re: Can our tranny's handle boost
Are you boosted by chance?
If I understand correctly, this could present a large problem in a boosted car because you don't want your oil pressure over 60psi.
Old Nov 17, 2004 | 01:19 PM
alz99's Avatar
Vehicle: FX Coupe
Default Re: FS: A few things (Lights, spoiler, antenna)
QUOTE (TibRacer01)
yep..
Old Nov 17, 2004 | 01:32 PM
2bits's Avatar
Default Re: FS-JVC KD-G700 and 1frd RF capacitor
Definatly better than high blood pressure Always gotta look at the bright side of things wink.gif
Old Nov 17, 2004 | 11:35 PM
Denisst99's Avatar
Default Re: www.arkspeedracing.com - ARK PERFORMANCE
with the engine hot, 5w30 synthetic oil
35 at idle and 60-65 at aroud 3500-4000 rpm
when the engine is cold i often see 85 psi at around 5000 rpm
autometer gauge hooked up to the stock oil pressure port (front of the engine)
Old Nov 18, 2004 | 09:13 AM
azwildfire's Avatar
measuring off the oil pressure sending unit on the front of the engine.
I have an I4 CVVT engine.
I got my turbo's oil feed from the head *used an easy out to extract the bolt* because when using the oil from the bottom of the block, i got WAY too much pressure.
had an oil change 1k miles ago. use 10-30 full synthetic (mobil 1)
you can also use a restrictor to lower the pressure going into the turbo
Old Nov 18, 2004 | 11:56 AM
alz99's Avatar
Vehicle: FX Coupe
cool, problem solved. thanks
