Transmission prob.
Old Feb 12, 2005 | 08:08 AM
jmt420's Avatar
Vehicle: 2000
Default Transmission prob.
Ok when my car is really cold and I first start my frst gear change is rough jumping about 1.25 grand in rpms, and when it is warm is will jump about.25 grand ? I just recently had my tranny flushed and fluids replaced. And suggestions?
Old Feb 12, 2005 | 08:37 AM
bluetibbay's Avatar
Do you mean when you start the car it jumps? Or when you put it into first?
Old Feb 12, 2005 | 08:48 AM
sounds more like it is hanging up in shifting.. pausing a moment between gears and allowing the RPMS to jump up before getting into the next gear.
Old Feb 12, 2005 | 10:30 AM
hamhead's Avatar
You mean the RPMs jump after you shift? Could be your clutch slipping, or maybe your hitting the gas while the clutch is still engaged. tongue.gif Assuming its a manual here though...
Old Feb 12, 2005 | 10:42 AM
CyberShark's Avatar
Yes, it would help to know if it was an auto or 5speed.
Old Feb 12, 2005 | 05:27 PM
jmt420's Avatar
Vehicle: 2000
It is a automatic, it jumps right before the second gear catches.
