Hissing sound??!?
Old Dec 29, 2004 | 01:26 PM
tanc's Avatar
Vehicle: 1997 Tiburon
Default Re: doing cam research
I was driving home from work, and I noticed when I accelerate I hear a Hissing sound I've never heard before, I let go of the throttle and it stops
I checked under the hood and played a bit with the acceleration spring and it seems to me the hissing is coming from the intake manifold ... But I dont hear it that well standing over the block. Inside the cabin you can hear it a bit better..
Just got a new flex pipe installed at the muffler shop... if it matters
Old Dec 29, 2004 | 01:31 PM
silvertibbs's Avatar
Vehicle: 2004 Acura TL
Default Re: Screw in rear rotor?
I'm going to sound like a broken record here but.......
Has it been difficult to start your car in cold weather?? The only hissing sound that I have ever had was when I warped my IM. It got really cold out and I couldn't start my car. 02.gif
Basically the engine is sucking in air after the MAF and stalling out.
Old Dec 29, 2004 | 01:39 PM
tanc's Avatar
Default Re: a few crazy pics of my 97 tib
not hard to start at all
Old Dec 29, 2004 | 03:08 PM
hamhead's Avatar
Is it running slightly slower? Sounds like a vacuum leak. Start the car, and spray starter fluid on different parts of the IM. If the idle changes, you have a leak.
Old Dec 29, 2004 | 05:40 PM
cbehage's Avatar
Default Re: Adrianna Lima anyone?
I know that my Idle cotroller makes sounds like a king cobra when it is cold. It gets amplified by the aluminum intake piping. Try unplugging it and see if it stops. laugh.gif
Old Dec 29, 2004 | 07:03 PM
CyberShark's Avatar
Default Re: Front Bumper
It might be an air leak. Check your hoses around the sound. If you spray glass cleaner on the suspected hose, the engine will surge a little if there's a leak.
Old Dec 29, 2004 | 10:39 PM
tanc's Avatar
Default Re: Being sick
QUOTE (hamhead)
confused 8O
Old Dec 29, 2004 | 11:11 PM
CyberShark's Avatar
Default Re: Parts
LOL...I guess if your starting a BBQ on your engine you can use the starter fluid...hell, maybe it works.. lol.gif
Seriously, I've never heard of starter fluid being done before (no offense hamhead, I'm just playing around)...I'll leave up to you tank which one you should use.
Old Dec 30, 2004 | 08:32 AM
Default Re: freakin' car dealers
actually.. it sounds like an exhaust leak. The tip off is the fact that when he gets off the throttle, it stops. I would say the flex joint is not tight or the manifold to cat connection is loose. When on the throttle, the engine and tranny "twist" slightly.. this is why you have a flex joint, so you do not break the exhaust system when they happens. Because this is only happening when the engine is "twisting" in the car, it means that a joint in the exhaust is loose and is being pulled apart by the engine's movement.
Old Dec 30, 2004 | 04:14 PM
tanc's Avatar
Default Re: FS: BBTB
okay i found my problem.. I have a crack in one of my header pipes
:x and I just replaced them 7 months ago..
