New engine...
Old Feb 5, 2005 | 10:55 AM
Grottenolm's Avatar
Default New engine...
Are there any problems with installing a 1st gen beta1 engine (out of an auto tranny tib) into my 2nd gen manual tranny tib?
Old Feb 5, 2005 | 10:57 AM
97blacktib's Avatar
ummm shouldnt be since you have the transmission already for it, but someone will jump on this with more details.
Old Feb 5, 2005 | 11:51 AM
hamhead's Avatar
Shouldn't be. Everyone has told me the ECU's are interchangable. I am guessing the manual should mount up right where the auto would be with a little work, but I am not certain. There will probably be a little bit of fabrication there.
Old Feb 5, 2005 | 01:06 PM
Dmitry's Avatar
Vehicle: Elantra HD / 2007
drive shafts for A/T and M/T can be different.
But if you are changing engine without transmition - it should be ok.
BTW. drive shaft from Lantra 1997 1.8 M/T ABS doesn't fit Tiburon 1997 2.0 M/T ABS.
Old Feb 5, 2005 | 01:51 PM
supercow's Avatar
the only thing i could think of is why not just find a 2nd gen motor? I guess it makes sense if you've already got the 1st gen. but there were improvements to the 2nd gen. motor over the first.
but other than that everything should be find. from outside they are really pretty much the same.smile.gif
