BAD DAY broken piston
it was a bad day today.........took my motor apart to change what I thought was a burnt exaust valve. well the valve's turned out to be just fine so got curious and droped the oil pan, poped my #1 piston up out of the block.......well the rings fell off in a million peices and my piston had a crack from the ring glands down the side and up under the wrist pin. the crazy thing is my car has been missing slightly since last january, I thought it was just a pinhole in my valve from drag racing and using nitrous. so realy my piston has prolly been craped out since then..........thats F-ing nuts because my car has been working fine except a minor rough idel.......well my mechanic buddy that helped me was very impressed that the car even worked as good at it did with the piston in that shape.....he also said that the dammage looked like it was a defective piston and it was prolly broke from the time I bought the car and the abuse I put the car through made it worse. ....lol
Bah NO2 is nice to pistons compared to other things... either way, I also would concur with your mechanic that your engine is a resilient little sucker and it probably has been like that all the time and putting the little bit more power through the combustion chamber weakened it over time. A little bit longer and it probably would've went KABOOM. So props for not being lazy and driving it like that for another year tongue.gif (doubt it would've lasted three months longer from what you describe, if that smile.gif)
Take this bad day and do something good with it.... maybe change to high compression pistons... or maybe bore the engine internals.... even you can change the intake cam......
But be sure that everything is OK internal.... a broken piston can do serious damage to the cylinder walls.... valves.... etc... just check and double check.... its better safe than sorry later.....
High Compression pistons just don't drop in. Need new seats, rings, etc. I doubt he wants his engine apart for a month waiting for various parts, and even then he runs nitrous. Nitrous + High Compression = Bad Idea.
You've got it apart... my recommendation would be to clean all the carbon, maybe mess with the intake/exhaust ports with a dremel if you can. If its your daily driver, just clean it.
If you can, by all means splurge on 16 new oversized valves, new rings, new bearings, etc. Save you some labor in the long run if you are going to put more power through your car. Hell, you could take a second mortgage out on the house and blueprint the block, drop in forged pistons, new rings, new bearings, new oversized valves. tongue.gif
