Looking for good clutch......
Old Feb 2, 2005 | 09:33 AM
cbehage's Avatar
Default Looking for good clutch......
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...sspagename=WDVW
I am looking for something good but not too pricey. Under $200.
Any suggestions?
Old Feb 2, 2005 | 10:23 AM
CyberShark's Avatar
Man, If I were you, I would change out the flywheel for a light weight one too since your gonna be changing the clutch...the VHR set up is nice but it's well over what you're looking for
Old Feb 2, 2005 | 10:36 AM
cbehage's Avatar
I can't spend that much right now. I am doing the tranny swap and have to buy
starter
flywheel
cluth kit
pedal
clutch cylinder
shifter
shifter linkage
other stuff
I am looking for something better than stock but not too expensive
Old Feb 2, 2005 | 10:38 AM
Dweet's Avatar
those two clutches look like the same design as the stock... unless the PP is stronger you really wont see much more of a difference if any
Old Feb 2, 2005 | 02:44 PM
well just remember.. if you are buying a USED flywheel.. you will need to get it machined to make sure it is not warped and that the surface is clean of any contamination that will adversly affect your clutch. If you are buying new.. it is likey not too be cheap.. so shop around, some places will bundle and clutch and lightened flywheel together for not too much money.
Old Feb 2, 2005 | 08:33 PM
bryce804's Avatar
i could give you my old clutch, but its a stock one and used for a year.
Old Feb 2, 2005 | 10:32 PM
cbehage's Avatar
I thought it crapped the bed on you bryce?
Mad....can you show me an example of a flywheel, clutch package? I saw the one on SR but it is $800!
Old Feb 3, 2005 | 12:51 AM
bryce804's Avatar
QUOTE (cbehage)
accually the clutch is fine!!!, it was the whole tranny that broke, hole in the bottom, all the gears fell out. itll be fixed tomorrow though!!! let me know if you want it. ill just give it to you for free. shipping shouldn't be more then 20.
Old Feb 3, 2005 | 01:07 AM
cbehage's Avatar
Yeah man I take it.
I am very grateful. I am trying to get all of the parts together fo the swap.
I am in 15228 for shipping info.
Wondering if you have any other tranny stuff for me. Like a starter and other things. Let me know.
Old Feb 3, 2005 | 06:23 AM
bryce804's Avatar
i might man. when i got to the shop today ill get you everything i can off it.
