96TIBURON/96ELANTRA Engine
Old Feb 12, 2005 | 12:30 PM
patdaman2k's Avatar
Default 96TIBURON/96ELANTRA Engine
How similar are the engines of these cars? Can I use performance parts off the tib and put on the Elantra?
I know this is a Tiburon forum but i figured it would be the only place to ask the questions im asking.
Old Feb 12, 2005 | 12:36 PM
CyberShark's Avatar
I know that it was the first year that the Elantra used the 1.8liter. I believe the Tiburon and Elantra both used this same motor.
Old Feb 12, 2005 | 12:52 PM
If you've got the Beta Engine, they are identical.
There isn't a 96 Tiburon however.
Sorry man.
Also, welcome to the forums, please FILL OUT YOUR PROFILE, you'll find it in the User CP area.
You need to list your location (at least a state), and your ride.
Old Feb 12, 2005 | 12:57 PM
patdaman2k's Avatar
Is there a difference between the 97 tiburon and 96 elantra engine?
Old Feb 12, 2005 | 01:00 PM
CyberShark's Avatar
That's right, the Tib didn't come out till 97. ^Like Redz said, if they're both betas, they're identical.
Old Feb 12, 2005 | 01:10 PM
I can almost guarantee your 96Elantra didn't have a Beta.
Old Feb 12, 2005 | 01:18 PM
patdaman2k's Avatar
Ok so no performance mod off of any year Tiburon will fit on my Elantra?
Old Feb 12, 2005 | 01:54 PM
'treezy's Avatar
go to hmaservice.com/webtech and type in info for 1997 Tiburon (1.8L or 2.0L beta, doesn't matter)
then search through the links on the left and click on engine tab, go through stuff until you see picture of engine. If your engine looks like ours (exactly) then you have our identical engine.
From my knowledge, I do not believe you do have the beta, i think it was only on the older Elantra.
there is Elantraxd.com as well which is more for Elantra (but you are welcome here....)
Easiest way to figure it out, post a pic of your engine bay and we will tell you if you do or not.
By the way, if he doesn't have the beta...what engine came w/ the newer Elantra's? name? specs?
Old Feb 12, 2005 | 02:32 PM
KayJai's Avatar
QUOTE (REDZMAN)
It did actually bud
1.8's Only though.
1.8 and 2.0's are almost identical.
98-00 Elantras had the 2.0's
Old Feb 12, 2005 | 05:42 PM
I don't know man, isn't the 96 the same as the 95 elantra?
Why don't you post some pictures of an engine that you can find online that looks like yours man, then we can help you more brotha.
