factory defects
Re: 1st gen hi-shark wing
my 2000 tib has a few problems. most of all my horn will not work and my car makes so screwed up sounds when i cut to the right and gets quite when i turn to the left. my tires have been balanced, rotated, and had the air pressure ajusted, but nothing. i have had my car looked at by a few garages and most of them are blaming the factory
Re: New Rotors Paint on
You probably need to replace your horn(s). First, check your horn fuse to make sure it's not that. As far as your noises when you turn, it could be that you need to replace your struts. How many miles do you have?
QUOTE (mega_ender)
Then I suggest you go to a different garage.
:roll:
First off....
Is the car used? - Do you know the history?
Has it ever been in an accident?
Get your struts and springs checked out.
What kinda "screwed up sounds"?
Blind guess in the dark, sounds like a wheel bearing. But without you discribing the "screwed up sounds" that's just a shot in the dark.
Re: factory defects
i have taken the steering wheel apart and the live wire wasn't carrying a charge after it went through a connection. since the steering wheel is stock i don't think anyone has really messed with it. and the fuse is good. after my amp and speakers blew three fuses i checked and replaced every fuse in the car.
Vehicle: 2004 Acura TL
Re: *Exhaust Listings* Currently Available...
I second the wheel bearing problem. Jack up your car, take your wheel and to see if it moves side to side. If it has some play then the bearing is gone and I suggest to get it fixed quickly.
Re: Roof scoop?
QUOTE (silvertibbs)
silver is right, most likely it's bearings. how many miles was there? if your garage didn't check the bearings somethings wrong.
Re: Concept theme
Maybe I have the same problem as him. When I turn my wheel all the way to the side it makes a grinding noise but the sound gets louder and softer like waving. I thought it was a scraping but i don't think it is. Also my right rear wheel makes loud thumps over bumps. Is that my springs? I have 60,000 miles on my car. Sorry, I don't want to steal the thread.
Re: factory defects
Vulcan, I think your rear problem is a bushing problem. Same thing with mine. I got that replaced and now it's gone. Is it like a loud click like something is loose.
As for the bearing, try the same thing as I stated above and see if that is the case. If not it could be axle related.
Re: Timing Belt
A front wheel bearing would be a low pitched, barely audible hum that seems to "thrum" throughout the car, raising and lowering in pitch as it the car moves.
