2nd gear bog
Old Nov 11, 2013 | 07:42 PM
SpoolinShark's Avatar
Vehicle: 2010 Hyundai Accent
Default 2nd gear bog
Hey guys and gals, have a strange issue that has been happening ever since I've had my tib and figured I'd ask about it. First off, I've had my tib for almost 5 years now and it has this strange, one time, 2nd gear bog when driving. No matter how cold or warm it is, when I start to begin driving and shift into 2nd gear the car will stumble for a few seconds and then will be fine. 1st gear has no problems nor does any other gear.
I've had 2 Beta I trannies in my car in addition to the current Beta II tranny so I think I can rule the transmission out. Also, I've had 2 different motors in as well but have re-used the same senors. The only CEL I have is for a missing 02 sensor but even when I did have a functioning one, this still occurred.
It's nothing super serious to me, just was wondering if anyone has had this happen before. I tried to do a quick search but couldn't come up with anything.
Old Nov 12, 2013 | 09:51 PM
Does it happen in 3rd if you skip second? Does it happen if you intentionally wind up the engine a little higher in first? Does it happen all the time or just that first shift of the day?
Old Nov 13, 2013 | 11:12 AM
Stocker:
As for skipping second and going straight into third, don't believe I have ever done that during my first drive of the day. Generally I shift from first to second around 2 - 2.5k RPM when I first start to drive for that day. I can try out winding a little bit higher tomorrow when I leave for work or simply drive a bit longer in first to see if that has any impact. It's odd that I haven't heard of anyone else having this issue.. During this time I've also had the 1.8 ecu in my car and it still did it then.
