What kind of grease?
Old May 29, 2014 | 04:33 PM
Sharkrider's Avatar
Vehicle: 2008 tib
Default What kind of grease?
My battery posts are starting to corrode a little and I have heard that you should clean them off and apply grease to them to stop them from doing it again. What kind of grease do you guys recommend considering there are so many different types. Thanks.
Old May 29, 2014 | 09:33 PM
first this
http://www.fcpeuro.com/products/crc-...FUMF7Aodb28Adw
then this
http://www.fcpeuro.com/products/crc-...FSMQ7AodTBcA6A
They sell this at the local Advance Auto and use it when changing batteries. It works like magic IMO.
Old May 29, 2014 | 10:36 PM
i8acobra's Avatar
Vehicle: '14 Ford F-150
Yep. I use similar stuff at work. Only use grease on batteries in a marine environment.
Old May 30, 2014 | 04:18 PM
Red Raspberry's Avatar
Vaseline woks good. Better get some of those felt washers to slow down the acid fumes though as the seal between case and battery post is shot.
