What kind of grease?
My battery posts are starting to corrode a little and I have heard that you should clean them off and apply grease to them to stop them from doing it again. What kind of grease do you guys recommend considering there are so many different types. Thanks.
first this
http://www.fcpeuro.com/products/crc-...FUMF7Aodb28Adw then this http://www.fcpeuro.com/products/crc-...FSMQ7AodTBcA6A They sell this at the local Advance Auto and use it when changing batteries. It works like magic IMO. |
Yep. I use similar stuff at work. Only use grease on batteries in a marine environment.
Vaseline woks good. Better get some of those felt washers to slow down the acid fumes though as the seal between case and battery post is shot.
