A question of torque (bolts not power)
Old Aug 20, 2014 | 04:42 PM
korean_ferrari's Avatar
Vehicle: 2010 GC 3.8
Default A question of torque (bolts not power)
If you tighten a bolt to 60 ft lbs, does it always take 60 ft lbs to break it free? or more? Had this conversation with someone earlier. I said if you tighten a bolt into spring steel (such as a lock washer), it would take more. Also, if you have given it time for the elements to play a role (which wouldn't take that long), it could be more or less depending on temperature and moisture.
Old Aug 20, 2014 | 06:41 PM
WytchDctr's Avatar
Vehicle: 14 EGT 2.0
I would think the temperature could change that a bit.. or corrosion.. so I am going with yes it could change.
Old Aug 20, 2014 | 09:15 PM
Tak82's Avatar
Vehicle: 1997 RD 4-door
corrosion or rust will change the surface tension between the thread on the bolt and on the hole.
i deal with many customer's cars that shudder the torque wrench when i tighten the lug nuts instead of the smooth turn to "click".
Old Aug 21, 2014 | 12:48 AM
i8acobra's Avatar
Vehicle: '14 Ford F-150
When you tighten a bolt to 60 Lb. Ft., it takes more than that to loosen it. Google "stiction". Once the bolt breaks stiction, the force required to turn it drops dramatically.
