Can you ceramic coat pistons?
Old Feb 2, 2012 | 01:40 PM
Sharky NRK's Avatar
Vehicle: 2001 Tiburon
Default Can you ceramic coat pistons?
And if so, what benefit would it have?
Old Feb 2, 2012 | 03:23 PM
Yes, ceramic coating is commonly done on pistons.
On the skirts, it decreases friction (not forever, it does wear off).
When it's done on the tops/face of the piston, it decreases the amount of heat the piston absorbs. In High performance engines it's done on both.
The piston absorbs less heat from combustion/friction which allows higher combustion chamber pressures (higher compression ratio, or fuel/power additive like Nitrous/Nitro-methane etc).
You can ceramic coat damn near everything in an engine, but the only parts that usually show benefits are piston faces/skirts, Head combustion chambers, intake runners, intake manifold, valves(faces, and stems), exhaust manifolds, turbochargers, etc...
Read moar here
http://www.swaintech.com/store.asp?pid=10296
http://www.swaintech.com/store.asp?pid=10298
