Checking oil level
Old Feb 29, 2012 | 01:17 PM
tribaltib's Avatar
Vehicle: 2000 Tiburon
Default Checking oil level
When is it best to check your oil level? Immediately after running the engine for a while, or after its been sitting for a bit? Wouldn’t it be better to check it after its been sitting for awhile so that the oil has time to drain back down into the pan, giving you a more accurate reading?
Old Feb 29, 2012 | 11:48 PM
Give it a few minutes to settle and you're probably close enough to tell if you are too low.
