Piston Rings??
Old Apr 4, 2002 | 05:52 AM
Brainiac's Avatar
Default Piston Rings??
Where is a good place to get some stronger piston rings for a 01' Tiburon running 9lbs of boost from a S/C?
Thanks,
Old Apr 4, 2002 | 06:13 AM
If Total Seal makes a set, that's the place.
Old Apr 4, 2002 | 08:21 AM
Total Seal has had a bad repuation for cylinder wall scoring, pistion damage, and sealing problems.
I would ask Onpol where he got his Chrome-moly rings for his stock pistions. Those puppies held up well for him.
Ross makes rings for their pistions, but they might make a set for the stockers if you throw some money at them!
Old Apr 4, 2002 | 11:22 AM
onpol's Avatar
Random is right. Don't buy Total Seal. I had them installed on my Tib when i got boosted and had some problems with the oil rings.Try to get Seal power custom made for the stock pistons or buy a set of pistons with rings.
Old Apr 5, 2002 | 05:16 AM
Is is an import/4cyl thing? Total Seal has a good reputation in the V8 circles.
Old Apr 6, 2002 | 04:18 AM
UFB:
Ballistic Racing have a set they use in their turbo kits, designed specifically for a turbocharged setup.
The cost is also much less than the rest of the market. $90.00 a set
That is a schweet price for pistion rings made for our stock pistions! Thanks UFB/Ballistic!!!
Old Apr 7, 2002 | 02:41 PM
Brainiac's Avatar
UFB
Where is Ballistic Racing located at?
Is there a Web Address?
Thanks,
