pistons
Old Apr 13, 2002 | 01:22 AM
Jon's Avatar
Jon
Default pistons
sorry if this has been answered already but i spend so much time away its hard to catch up on all the posts.Is there anywhere i can get better pistons and rings that dont lower the compression(as i have the alpine kit with spacer) or something that will lower it by the same amount if i remove the spacer. Iknow there are better ones from searching but the thing is i dont want to change the compression to much, but if i have to well then i will.
Old Apr 13, 2002 | 11:23 AM
If you contact Darius (Dar-re-us) at Ross Pistions, he will make a set of pistions to your specs. Stock bore? Slightly overbore? Your choice.
5:1 compression or 15:1 compression...your choice.
Just let him know what you want, and they will make them up for you.
Old Apr 14, 2002 | 12:05 AM
2 UNIQ's Avatar
Whats the contact number?
Old Apr 14, 2002 | 05:34 AM
2 UNIQ:
http://www.teamsr.org/cgi-bin/ultimatebb.c...c;f=16;t=001106
