Is this intake any good????
Old Apr 10, 2002 | 08:46 AM
Iceman91's Avatar
Default Is this intake any good????
I think aerospeed makes it is a like a blow off valve type intake. Wut is this thing do?? Does it whistle like a blow-off valve?? Is it any good????
Old Apr 10, 2002 | 01:22 PM
arn's Avatar
arn
you got pics on what this thing look like?
Old Apr 11, 2002 | 12:51 AM
Iceman91's Avatar
http://www.import-zone.net/
It is the one in blue down the page it is under the short ram intake heading 1st set up under it in blue. Is that filter any good??? Does it make a whistle sound Or a deep throughty sound????
Old Apr 11, 2002 | 12:57 AM
WhoopOi's Avatar
Aerospeed as some nice stuff... never heard of that intake, sorry... so I couldnt tell ya, but it looks nice.
Old Apr 11, 2002 | 01:09 AM
DESIGN's Avatar
The blue thing on the end is not a filter. What you are seeing is a heat shield. The filter is a regular cone inside that protective cover.
Old Apr 11, 2002 | 02:25 AM
ONLY1DB's Avatar
dude i wont waste the money i would wait for sr's cai to come out or even kore's....aos makes one as well! there are a bunch that are coming that will perform alot better!
Old Apr 11, 2002 | 03:54 PM
Iceman91's Avatar
ok thanx i wuz just wunder'n if it made a whistle'n sound like a blow-off valve does since it is called a blow-off valve style intake.......
Old Apr 11, 2002 | 05:46 PM
Etep's Avatar
I had one. The HKS BOV type. But it was cheaply made. The filter area is so much smaller than a regular K&N cones or any others without the shield that you are in no way sucking more air than stock. And there is no BOV sound dude, that is just a plastic cover. It's built mostly for civics that needs restricted air for low rpm torque.
(what I have) is better than (what I tried) if you are looking for more air.
Old Apr 13, 2002 | 05:28 PM
Iceman91's Avatar
Thank u buddy u have been the most help on this forum so far..........
Old Apr 14, 2002 | 05:43 AM
That Aerospeed unit is just a air filter cover that is designed to LOOK like a Blow Off Valve. No, it makes no special sounds.
Anytime you are covering up part of the air filter you are restricting air flow. Reactive is the most common, but others like aerospeed are now trying it.
Any miniscule gains from blocking heat are negated by the horrible decrease in air flow you get by blocking off 75% of the air filter.
Just use a normal "cone" or 'round' filter.
