LSDs?
Old Apr 22, 2002 | 03:39 PM
Julez's Avatar
Vehicle: 2008 Accent
Default LSDs?
Could someone clear up the differential stuff for me or provide me with a link that could explain it?
From what I understand or have read automatics don't use LSDs? is that correct or no? If not then what is there for the autotragics?
Old Apr 22, 2002 | 05:18 PM
www.howstuffworks.com
Explains manuals...automatics...and Limited Slip Differentials.
Old Apr 23, 2002 | 07:59 AM
Julez's Avatar
So just to double check here, from what I understand if quaffie were to make a LSD for the manual it would still be able to be put in an automatic, I checked out the webtech website as well and from all the knowledge that I've gained they look identical.
But I was just going to check.
This was all leading up to my final question about the differential problem with the tiburon being a problem in both A/T and M/T.
Thanks Random
Old Apr 23, 2002 | 02:25 PM
No, the same LSD will NOT work in an automatic. The inner workings are significantly different.
I do not know if the Auto's have the same problems as the manuals, as no one has YET put that much power through an auto.
A level10 upgrade for your tranny is your best bet if you plan on putting serious power through the autotranny.
Old Apr 24, 2002 | 02:07 PM
Julez's Avatar
That is going to be my plan now, to hopefully do a turbo install with one of the many kits that will be available at that time, as well as the Level 10 upgrades.
[ April 24, 2002, 09:09 PM: Message edited by: Julez ]
Old Apr 25, 2002 | 12:10 AM
Ketchup if Tucan's Avatar
mmmmmmm. LSD...
Old Apr 25, 2002 | 12:32 AM
Julez's Avatar
Old Apr 25, 2002 | 06:47 AM
rx bandit's Avatar
Vehicle: 2000 Tiburon
[QUOTE]Originally posted by Random:
[QB]
What about the 600 hp twin engine turbo tib from sport compact car. Is he running without a LSD? He was a twin autotragic.
Old Apr 25, 2002 | 02:56 PM
Julez's Avatar
I would think that would be different though, it would have to have two differentials for each engine I would guess. But I have no idea how that car is truely setup.
Old Apr 25, 2002 | 03:04 PM
Veniston's Avatar
Yeah, each engine has its own transmission
