Those with automatics
Old Apr 18, 2002 | 10:06 AM
XtremePc's Avatar
Default Those with automatics
Do you Have actual Speedo Cable or just a sender
as my auto has no cable just a electronic sending unit right on the trans with wires that go to the speedo
Old Apr 18, 2002 | 01:49 PM
The tranny sends the cable signal to the tacho. The tacho converts that into an electrical signal which is fed to the speedo. The speedo then via a reed switch sends the speed signal to the ECU.
Automatics and manuals work the same way.
Old Apr 18, 2002 | 03:11 PM
XtremePc's Avatar
Cool Thanks random
Old Apr 18, 2002 | 11:24 PM
Shadohh's Avatar
Yeah, if your are worried about doing the tranny swap. That want be a problem, direct plug in between the two.
